jwaller
- 20
- 38
- Columbia, SC
I gotta ask, whats with the warn decals?
I was in a Warn commercial a few years ago on Spike TV; I just never removed the decals.I gotta ask, whats with the warn decals?
http://www.youtube.com/watch?v=F652JOD7OK4
2x4x.120 rectangle tube; used it for most of the frame, sides, cab guard, etc.What size rectangle tube did you use for your bed?
Thanks!! I'm about to build a flat bed for mine and the size you used looks perfect for the size of the truck.2x4x.120 rectangle tube; used it for most of the frame, sides, cab guard, etc.
Can you post a few photos of this? I'm interested since the CTIS on my 5-ton is not very reliable.Just a quick update in the continuing ownership "saga" of my Deuce!
I put together my air fill/drain rig for the new valve stems on my MRAP wheels; it works great. Having those large bore valve stems is GREAT for quick air adjustment. I typically reduce air pressure in the tires when off road, and it usually takes close to 30 minutes to air them back up. Hopefully this will shave a few minutes off of that time.
thanks.
Yes ! Pictures of the seats and where did you get the seats, who makes them ?That's pretty cool! Also how did your seat upgrade work out? What seats did you end up using and would you do anything different if you did it again? Any pictures of the new seats mounted? Thanks
Attached are some pics of the seats installed in the deuce (took them this morning). Hard to get a good angle inside of the cab! The're still a bit dirty from my last outing...Yes ! Pictures of the seats and where did you get the seats, who makes them ?
Thanks.
