2.5 ton rockwell how much can it take?
Ryan123
Brighton, Colorado
I was wondering if anyone knew how much abuse the 2.5 tons can take? The reason I am asking is I am heavily considering swapping my deuce multifuel out with a 6v92TAB with twin turbos and large injectors. It will produce around 500+ horse at 2100 RPM and I'm guessing about 1300-1500 ft lbs of torque. Has anyone blown one up with 6bt? or something similar? Or are there any spec sheets out there with exact specs?
The ultimate plan is to make a very nice camper set up and towing unit for a do it all truck. I just cant break down and spend 60 grand on a pickup!
I have a lot of experience with two stroke detroit diesels that is why I would put one in rather than any other motor.
Thanks guys!
Ryan
gringeltaube
Staff Member
2,687
Montevideo/Uruguay
..................... I just cant break down and spend 60 grand on a pickup! ...............................................
No, but you will spend more than that, replacing every part (not only the T-Case) if you ever let that motor put out its 1000+ ft-lb of torque!
I would even think twice before putting that beast in a M939 series 5-ton.
G.
Ryan123
Brighton, Colorado
found this on another thread didnt want to advertise that forum here but im sure you can all guess
"The 2 1/2 ton U joint style, max. static load is 3,600 foot lbs. of torque. The convel model "E" used in the 2 1/2 ton is 4,310 foot lbs. of torque. The rezepa is estimated 10% to 15% weaker than the U joint style. Just for grins the dana 60 - 1480 in the [COLOR=#00FF00 !important]steering[/COLOR] axle is 2,000 foot lbs. of torque. I like BIG stuff. steve differential eng.
Ryan123
Brighton, Colorado
apparently the 2.5 ton axle can hold 12000 pounds from some searching dunno if that is true or not but they do say the deuce can haul 5 tons on road safely. That being said what about the t case it is pretty big and tough....looking lol
Ryan123
Brighton, Colorado
well I would have to agree with you but... how much can the 2.5tons handle? I can back the power down out of it if needed I would like to know were the limit is. I am not going to be rock crawling this thing, it will be going over the mountains to go camping ect. Also pulling some loads i'm sure.
w3azel
Waipahu/HI
Id use that money for 5 ton internals. The drivetrain will probably do fine as long as your not crazy on it. Going off-road in a mud hole will probably end with you breaking stuff. Driving and towing you should be alright as long as your not trying to race people.
Ryan123
Brighton, Colorado
Really? 4.90 ratio gear set change X 3 chunks = $5.500.00 + 27% OD. You looking at doing 120 mph?
Here ill do the math for you. The gears cost 1200$ each so that's 3600 bucks not cheap I know but its better than a brownie box (hacked in).
Here is the math
2100 RPM divided by .63 trans OD =3333.33 divided by 4.90 axle ratio= 680.27 times 10.55 rolling circumference of my 43 inch tires at 96 percent =7176.87 feet per minute times 60 minutes = 430612.24 feet per hour divided by 5280 feet per mile =81.55 MPH
that being said I DO NOT WANT TO RUN THAT FAST however without the gears you get 59 mph. I would like to run 65 MPH at a lower RPM for better fuel consumption and not have to have the motor pegged out.
Ryan123
Brighton, Colorado
5 ton third members fit into 2.5tons?
welldigger
Benton LA
No. But 5 ton axles have been shoehorned under deuces numerous times. Bet you could get some take out 5 ton axles for around the same money as ouverson gear sets. Though they would need to be the older 5 ton axles with hydraulic brakes. Unless you want to convert to disk brakes. In which case it probably wouldn't matter which 5 ton axles you use.
