oddshot
- 121
- 43
- Jasper, Georgia
But you dug in and got it done. I hope it runs as sweet as ever ...Head gasket front head. Hard job for a 72 year old
Yeah its been non stop. Every chance I get I'm working on it. Front Axel seals will be done on Friday.Wow you have done a lot of to work in a short period of time can't wait to see it next month
Will those stop the whole front drivetrain from turning when not in use?Traded a radiator for these, put them on today!View attachment 513463
Do you have power steering on your deuce? I hope you do. That spool will be a bear in deep ruts and obstacles with manual steering!I plan to install a spool , which is like a solid axle, so that when I disengage these lockouts, no wear on the front axle at all, but when they are turned on, its 100% aggressiveness, ( and Im told the spool has a mind of its own, they self steer)
He did not. I forgave him anyway.Did Brutus listen?
Only if you have an air shift transfer case!Will those stop the whole front drivetrain from turning when not in use?
