Running power tools off the slave port?
SCSG-G4
PSVB 3003
3,193
Lexington, South Carolina
If you want to run an impact off the slave port, get one of the Robo-Tools. 1/2 inch is only rated at 350-400 ft/pounds, but the 3/4 inch is a lot beefier (and expensive, even on the surplus market). Ferro is using mine right now in the repower/reconstruction of 'Bella'.
Skinny
486
Portsmouth, NH
Ahhh that's called humor:razz:. Sorry, old surfer kid from FLA. it's just "ah" tongue and cheek representation of my Spicoli-esk accent.
No doubt ah yut
Seriously, a small 2000 watt generator off craigslist will let you run most tools all day long without having to refit everything to the Cuck. Or simply run air off the engine or run cordless...feel like this is reinventing the wheel unless you already have the mil spec tools that are plug and play.
Mainsail
1,437
Puget Sound, WA
This.
Using the 24V port (or the bus-bar), or an air compressor on the engine, or an inverter means your 6.2 diesel will be running the whole time. Excess wear and tear of the motor and electrical system, noise, stink, etc…. to cut lumber or drill holes? How is that better than cordless or buying a small Honda generator?
Drock
9
Eatonton GA
This.
I guess I'm just looking for the convenience of having these tools ready to go if and when I would need them. I would only use these on occasion, but it would be for hard work. The saw would need to be able to cut through several 3" X 24" X 20' wood planks. And the impact would only be used incase of ah flat tire. If they simply ran off the truck I could throw them behind the seat and forget about them.
goldneagle
857
Slidell, LA
You have the option of chainsaw for the planks.
Skinny
486
Portsmouth, NH
Sounds like some on-board air and a chain saw would fit the bill!
Seriously, all you wankers would be worry free with a M1031. I carry my generator, air compressor, and welder with me everywhere I go...why is this such an issue???
Drock
9
Eatonton GA
Ha! well for starters I don't have ah shoe box bolted to the back of my truck to store my garage in:cookoo::-D. Seriously though space is ah commodity in the cab of these trucks. Unless you can have ah "normal" tool box or camper shell, of which I can't use because they'd be in the way.
Skinny
486
Portsmouth, NH
Haters be hatin' today!!! :)
I need a wheel chock because one day I will get a real MV and then...uh hem...will need a wheel chock!
OBA could mostly fit under the hood and probably could sneak a few impact tools under the seats up front.
Drock
9
Eatonton GA
Your truck does look cool as heck though, I just couldn't use one with ah box on it.
Recovry4x4
LLM/Member 785
1,814
GA Mountains
FWIW, the 2663 Milwaukee impact will remove the lugnuts on any CUCV. I guarantee that. If there is anybody on the fence about the Milwaukeen feel free to come see me at the GA Rally and take a spin.
m109a2
lake charles la.
Hey guys most of the ac motors now days such as skill saws,drill motors and such are universal voltage,They work on ac or dc.A common mistake is that some will try a 120 volt impact on 24 volt dc,This will not work well.Try to series at least 6,12 volts depending on load. Add more to taste.
Crash_AF
Colorado Springs, CO
I have a Snap On 1/2 cordless impact that I swear by. It has never failed to break a lug nut loose on anything smaller than a deuce when the pack is fresh. I hardly ever break out my IR pneumatic gun anymore.
Joe
chongo
whitethorn CA
New guy here. Just figuring out my M1008 . This is my first diesel and I'm loving it so far. At first I was shocked by the lack of power compared to a gasoline motor. Are you talking about the electrical cord end that sticks out of the grill? What is that? Sorry for novice type question. I'm going to start studying the TM's but haven't had much time as of yet, I've only had the truck about 6 weeks.
cucvrus
9,603
Jonestown Pennsylvania
Joe
Rock on with the cordless Snap-On Impacts. They are the best. I removed the entire front and rear axles and springs from an m1028 with the 1/2" cordless Snap on impact. I used the 3/8" drive to remove and reinstall 2 sets of wheels and tires from an M1031 to an M1008 and it still had 2 bars on the battery indicator when I finished. They are by far the best. I have the others Dewalt & Milwaukee but Snap - On has the best. No comparison. A bit pricey but well worth it. Not designed for amateurs. they are professional tools with a professional price. Sorry but it is the truth.
SCSG-G4
PSVB 3003
3,193
Yes, that's the slave port. Read the TM's, especially the one that ends in -10, it's the operator's manual.
