dirk721
- 0
- 1
- Lakewood, CO
Well, I'm a long time reader of this site and have had tons of help from reading posts to help build my rigs, but I'm finally starting my first post.
I'm wondering if this is a good idea or not since there are only 3 stock mount tabs on each side of the 5 ton from the bed to the frame. I do a lot of towing/hauling vehicles but the 6 total stock mounting tabs on the 5 ton that allow the bed to flex from the frame seem inadequate for the amount of pulling from body-roll on the M1009 that would be up there. Should I make some more mounting tabs from the bed to the frame or were these stock beds/mounts made strong enough for side to side pushing or pulling that a vehicle up that high wouls create? I'll be welding some heavy D-rings inside of the bed for tie downs on the tires. The total height will be 12'10" to the top of the roof rack. I'm a little under 5,000 pounds on the M1009 so it's technically half of the rated bed capacity.
I would love to hear some thoughts, ideas or experience on this matter. Thanks for the help in advance!![beast on tank.jpg beast on tank.jpg](https://www.steelsoldiers.com/data/attachments/374/374584-747d54893e4b24f6b1b77430d1dc6385.jpg)
