gem1410
- 44
- 28
- TOMS RIVER NJ 08527
What engine oil weight does the trans use and how many quarts does each hash mark equal----this trans uses motor oil--thanks George
That is ture, On a new truck I check it cold then drive it a little and check it again.Kind of a catch 22 though since you dont want to drive it to warm everything up till you make sure the trans has proper fluid level.
My truck took 5 gallons, but I also had the pan off and changed the filters.10-30 diesel motor oil looks good for NJ temps---what is the oil quart amount for the hash lines on the trans stick --that is what I would like to know--did not see that info in the manual--thanks
