Ok so as promised, Her is my attempt at changing the rear hub seal
Below:I was hoping the drum would slide off, originally i thought the wheel cylinder went out due to the massive leak only after i put in some break fluid witch latter on i found out i used the wrong kind. (ill fix it later)
Below:Had to pull out the Whatsits from the thingymabob. "JOKE" The spline shaft from the hub to remove the drum.
Below:After i removed the shaft i took a photo of the inner seal so i could blow it up to see better
Below:the blown up picture showed a torn inner seal, i dont have the proper tools or the time needed to do that job now. i ordered the seal and later will Finnish the axle.
