steelandcanvas
- 88
- 48
- Southwestern Idaho
Try it and see, if not, run a ground wire from one of the mounting bolts to the cab tub. You should be able to pick up a good ground there.So if I bolt one of the single-wire versions to my hardtop, will that be enough of a ground to make it work when power is applied? I know there are rubber seals between the various sections, but will the bolts and nuts complete a ground circuit for this light?
