metal to metal contact noise where the transmission and motor bolt together
84cucv1ton
New Jersey
when I got back home I took off the inspection cover. It looks like the weight on the flywheel is hitting something. The flywheel itself seems to be in okay shape. I turned it over by hand. Teeth look fine doesn't appear to be any cracks from what I could see. Any ideas? Thanks a lot[thumbzup]
Drock
10
Eatonton GA
Sounds like the notorious loose flywheel bolts to me. If your lucky it's the bolts or nuts to the torque converter check those first. Otherwise it would be the bolts to the crank. You may not be able to tell just buy moving it by hand. Try looking at it with the truck running and a trustworthy friend to rev it for you.
