New from Ohio, M1102
Spartan0341
Ohio
Does anyone know what connector/adapter I'll need that goes from Mil 24v to Civ 12v system? and what led lights I need as well? Im running the 7 pin on my H2. I would like not to have to hack up the factory wiring no the M1102. Thanks guys.
gottaluvit
Hello, from Ohio as well. You probably are who out bid me. Not like I needed one anyway. However I did get me an M101A2 in Illinois, and a M1061A1 out of Louisiana, so I am happy.
As for the lights, you can put 12V bulbs in the sockets, and there is plenty info on the wire adapters on here.
FloridaAKM
395
Gainesville, Florida
Welcome from Florida. If you are in a hurry to get it home without changing the wiring harness; get a set of magnetic lights from Harbor Fright, stick them on the STEEL land leg stubs in the rear, tie wrap them for safety & plug them into your vehicle 12v system. Problem solved easily. Watch your axle hubs for heating problems with bearing & brakes dragging early in the trip & you should be good to go. I have another recovery trip scheduled for Saturday for one in Southern Florida. Good luck with yours!
gimpyrobb
dumpsterlandingfromorbit!
27,791
788
Cincy Ohio
If your looking to specifically install omni-volt led tail lights so it doesn't matter what your tow vehicle is, there is about 100 led tail lights here in Dayton. Send a PM to Ziggy or Mwmules if interested.
