74M35A2
- 339
- 83
- Livonia, MI
I'll throw this in Parts Wanted also, but does anybody have a source for the radiator core-tank gasket/seal? Thanks in advance.
Was this an easy job? Mine is leaking but I do not want to start something I can not finish.I bought a roll of 36 inch by 18 inch by 1/8 inch cork gasket and traced the end caps then used a half inch hole punch whole thing cost maybe 8 bucks
Cinman I thought it wasn't very difficult. If I had to do it again I would leave that heavy rad in the truck. Some things to think about before you do it is to take plenty of pictures ( bracket placement, bolt direction,etc) Have new or good used end caps in place before you start or a place you can order them from. When I took mine apart there was metal pitting on the inside. Not bad enough to worry about,but something I would do before I started, Also you'll need high temp gasket sealant,and a good brass wire brush. Other than that it's a pretty straight forward job.Good Luck.Was this an easy job? Mine is leaking but I do not want to start something I can not finish.
I'm sure your local radiator shop could order them for you.I would like to find out where to buy the rods for poking thru the core with the end caps removed. Also, most shops just use cork and a gasket punch set to make their own end cap gaskets one at a time. No one stocks them.
