V8srfun
- 538
- 93
- Altoona pa
Sweet looking truck
No problem fixing your IP but you are needing to fix the address line. US is not correct answer for location.The fuel tank, apparently, had quite a bit of trash in it and was replaced.
Button fell off of the HH most likely. Possible stuck shut down cable or lever. You'll find those when you go to remove the HH.Just had one dropped off today in bithlo. First one for me. Only problem is no fuel to injectors. New tank and pump, filters are new. Nothing at injectors. Any suggestions?
