Ford Mechanic
- 10
- 38
- Edenton, NC
Not right off hand, I left the adapter with the pop tester when I left the Ford shop. I got the brake line and nuts from a local truck hardware shop that makes our hydro hoses.
Attached is pictures of injector
- low pressure @ 223 bar (should be 248-259 bar)
- sticky, bad spray pattern
- rust & old fuel (pressure adjusting screw, nozzle, etc)
$10 each to test & advise
Waive test fee if serviced –
- service holder $30. Each (1.60 each for shop supplies, ect.)
- service nozzle $15. Each – or cost of new nozzle
NBM770138 new ambac nozzle $80. each usually comes with nozzle gasket
- GA79148 s/s GA404115 adapter gasket $1.62 ea – need to order -
I agree about the spring settings also. Used springs need to be set at 2800 psi. They are charging a little higher then normal amount for basically a good cleaning and setting of the pressure. This is in no way a rebuild though. A rebuild would have new springs and nozzles and pins installed. I've never seen anyone break down the cleaning to clean holder and clean nozzle. It is a unit, a whole thing. Not pieces of a working device, but an integral working device itself. So when they say they will clean your injectors, they clean all of it. So $48.00 is a higher then normal price for injector cleaning.They're doing a rebuild. $48 for that doesn't look bad to me, but my experience with these injectors is limited.
If they are replacing the springs, then the 248-259 bar pop pressure is a little high, but close. That's about 3600-3750 psi. The info I found said new springs should be set at 3,400 psi (234 bar).
2800 psi (193 bar) is supposedly what the springs settle down to after breaking in. The book says the new springs "take a set" to 2,800.
I would be hesitant to set used springs to 3,700 psi pop. That's too much pressure on the injection pump. (My opinion based on the TM.)
At least yours are getting worked on. Mine are still sitting on the shelf at the shop. We still don't have a solution to connect the injectors to the pop tester.
Depends which style of injectors you have. One takes "shims" to adjust the spring tension. The other has an adjustable screw to put pressure on the spring. Of course everyone loves the adjustable screw one. The shims can be hard to come by. "Ford Mechanic" had some A/C shims that worked OK. You can ask him what they come on and where he got them.I got a dumb question how do you adjust and set the pressure. I'm just curious being I never seen anyone say how
That's good to know about the injector nozzles. Bad for you of course.I'm interested in how your pop tester works out.
On my end, I thought I had worked out a compromise to save a little money. You see, I had a set of new injector nozzles purchased here on a SS group buy a few years ago and the injector shop said they would knock $15 off the service price if they used my new nozzles. Sounded like a good idea so I went with it.
Well, the shop just emailed me. The nozzles I bought on the SS group buy do not fit my injectors. Go figure!
My injectors are the newer type, my best guess is the nozzles I bought on the group buy fit the older (shim) style injector.
Oh well, at this point I'm just going to pay the extra money for the service. This shop has serviced multifuel injectors before so I know what they are doing. One well-known place to buy military trucks in Maine is Schott's in Lewiston. Schotts uses this same shop to service their injectors. When I do this again for my second deuce however, I'd like to try the work myself now that I have a little more knowledge about the process.
What shop were you talking to? I was looking to go to Turbo Diesel and Electric systems 4923 Canton Road Marietta, GA 30066 (770)424-0330, wasn't sure if you had spoken with them. I believe their shop in Forest Park rebuilt the IP in my truck before I got it. So I thought I might try the canton shop just in case. if nothing else maybe they would be willing to ship things between their shops for me. If its even possible for them to do the work. But their site says they service and repair [FONT=Verdana, Helvetica, sans-serif]AMBAC/Bosch so I wasn't sure if you had spoken with them.[/FONT]Does anyone know of an Atlanta area shop that can pop-test these AMBAC injectors?
That's the one. Real nice people and they seem to do a lot of diesel work. My father-in-law uses them for his dump trucks and heavy equipment. He just couldn't figure out how to connect the deuce injectors to his pop tester.What shop were you talking to? I was looking to go to Turbo Diesel and Electric systems 4923 Canton Road Marietta, GA 30066 (770)424-0330, wasn't sure if you had spoken with them. I believe their shop in Forest Park rebuilt the IP in my truck before I got it. So I thought I might try the canton shop just in case. if nothing else maybe they would be willing to ship things between their shops for me. If its even possible for them to do the work. But their site says they service and repair [FONT=Verdana, Helvetica, sans-serif]AMBAC/Bosch so I wasn't sure if you had spoken with them.[/FONT]
I gave my hydraulic hose shop a piece of injector line from a deuce which they cut and spliced that to a hose. I told them it could be around 3600 PSI and then they worked their magic on the connection to the pop tester.That's the one. Real nice people and they seem to do a lot of diesel work. My father-in-law uses them for his dump trucks and heavy equipment. He just couldn't figure out how to connect the deuce injectors to his pop tester.
