High/low beams switch replacement
Gunfighter1
AZ
I was adjusting my headlights and switching between high and low beam when the turn signal lever stopped clicking and going in between high and low and is just stuck on low. What did i break exactly? The switch itself which i see is a relatively cheap part or the turn signal hi/low lever? Just want to order all the right parts the first time so i can fix it right. Never taken a column apart so not sure the exact parts and nomenclature that could be the problem. I'd rather fix it myself to and save the cash and learn how to do it than pay a shop to do it.
cucvrus
10,504
Jonestown Pennsylvania
Easy fix. Just take your time. Remove the lower cover from the dash and the lower column cover from the cluster column. The swith is less then $20. and get be had at any parts store. You will encounter a close fitting tight area to work in. You only need a 3/8" socket and wrench and a 5/16" socket and wrench. take your time. And adjust the switch till it works smoothly. The rod can be taped to the column to keep it from falling out of the lever. good Luck. About and hour or so standing on your head and it's done. No really itis not that bad. Just very small fasteners to deal with. Take a picture so you know how it looks when it completed.
TGP (IL)
36
Metro East IL
You don't take the column apart.
The switch is mounted to the outside of the column by the Ign. switch under the dash.
Follow the above post.
You can also search U-tube.
Many videos there detailing the process.
Tom
Gunfighter1
AZ
Tom
Great, thanks for the help you guys are awesome! My lower part of the dash that covers the column is already off, been that way for a year or so now. Do i need to drop the two bolts that hold the column up to the dash to get to it? Also is this the right part to replace? http://www.rockauto.com/en/catalog/...,electrical-switch+&+relay,dimmer+switch,4340
