Wait Light works intermittently
captkennyboy
farmington hills mi
Hello to all. the wait light works intermittently. used to work fine until the run switch was left on and the batteries went dead. replaced one but the other one took a charge. Now the wait light flashes quickly and the truck is hard to start. I have read the other posts but wondering with leaving the switch on and draining the batteries if anyone has an idea were to start first before I start replacing things
thanks for the help in advance
ken
1 Patriot-of-many
87
Zimmerman MN
Leaving the switch on either killed your board or wasted the glowplugs as they stay energized. Unless you have the non swell, self regulating glowplugs. I'm guessing your glowplugs are toast. I would test your glowplugs first thing. I'm betting replacing your glowplugs about $60 with new glowplugs non swell, self regulating will do the trick. I hope yours come out easier than mine did. I had to buy the special tool to get most of mine out and one tip broke off. Luckily it went out the exhaust after scaring the crap put of me with the rattling when I started it up without realizing the tip had broken off. I took a chance once I realized the tip had fallen into the cylinder and ran it for a minute or so and the tip luckily took a good bounce, got stuck in the exhaust valve for a second or two and exited.....Not recommended..
Plugs I bought: http://www.accuratediesel.com/shop/115.html
Glow plug extractor http://www.jjandaracing.com/contents/en-us/d9.html
1 Patriot-of-many
87
Zimmerman MN
thanks I'm new at this so I'm assuming that if I remove a glow plug I can tell if it's cooked
Do a search on here for testing glow plugs. They should have a certain resistance with an ohm meter from the plug connector to ground. Can't recall off hand what the range is supposed to be.
gcbennet
Trenton, ON
Yup, when I pulled and tested all of mine they all metered between 2.0 and 2.5 ohms. You can hold them right in your hand and hold the red probe to the GP's connector tip and the black probe to the collar. I suppose you can meter them while still installed, but I personally would recommend taking them out first so you can carry out a full inspection.
