sargentwolf
- 1
- 18
- st louis/mo
So my LMTV has an annoying issue Ive discovered.
The fan runs VERY often. On the road at speed, usually every other minute for 30 seconds then shuts off. Vehicle is unloaded, I dont have a tarp installed, not towing a trailer. Im usually running at around 50 on the highway, not flat out and over STL highways, so mostly flat roadways.
Temp gauge says its at 215-220°F when fan starts, runs, drops to 200°F, shuts down, repeat. yes, STL is going through a massive heat wave, but has been going on at night, ambient air usually around 85°F. I dont like to run or work on the truck in the heat, wayyyyy too hot right nowadays.
Should I start by changing the belts, do a radiator flush/fill, or what? Its not overheated YET, but want to nip this in the bud.
