how to tell the difference (looking at engine) between a 6.2 and 6.5L?
rookie
portcharlotte fl
If u can see the engine from behind there is a yellow tachometer in the middle of the valley if it has a bolt on the right its a 6.2 if the bolt is on the left its a 6.5
racing4funn
Chattanooga Tennessee
I was hoping there was a way to tell from the top and or front. It was the auction trucks Im wondering if they could be miss labeled and how I could identify that from the pictures they show.
joeberg
Atlanta, GA
Probably half the listings I have checked showed this area of the engine in at least one of the pics. I have found 2-3 that were mislabeled on GP including one I won.
steelsoldier1991
texas
after looking at pictures i noticed the lip where you bolt the transmission is different lengths as well
6.2 has a shorter lip
Swfb
99
Netherlands
When you can see the rear side of the engine you can see the difference in the seal. The 6.5 has the seal that's replaceble from the outside. The 6.2 has a 2 part seal that can only be reached when removing the oilpan.
Also the 6.2 normally have the 3 belts and the 6.5 a single serpentine belt.
Coug
4,842
Olympia/WA
except that the 6.2 got replaced by the 6.5 detuned decades ago, so any truck that went though rebuild would receive a 6.5 to replace the 6.2, but kept the V-belt system.
