4l80e to np205
Nessmuk
Tti Cities, VA
I've got a 4wd 4L80E, and want to mount up a np205. I plan on using one from a th400 out of a cucv. Anybody know what needs to be done to the trans tail shaft and the t-case adapter?
I'm already aware of the driveshaft and shifter changes needed.
I know I need two sensors on the transmission for its computer.
I think I just need help with mounting the np205.
86m1028
17
Murphy TEXAS
It can be done a number of different ways,
I used a 2wd trans, cut a small amount off the output shaft, machined the groove in a figure 8 adapter,
also had to clearance some on the adapter to clear the pan on the 4l80e.
Used factory crossmember & poly mounts.
Really depends on what parts you start with.
Now that is finished, I have the factory 4l80e/205 setup from a 91 crew cab as a spare.
86m1028
17
Murphy TEXAS
I am wondering if there is a signal generator available, run off the speedo cable, to give an output signal to the computer.
Check out jagsthatrun.
There are a couple companies that can machine the tail housing on the 205 for the tone ring & sensor or if your lucky enough to find a 91 np205.
Nessmuk
Tti Cities, VA
It took 10 hours, 2 flat tires, 2 dead batteries,
1 overheat, I lost belt, 1 wrong spare belt, 2 hours in Rutland VT finding a belt to fit, and driving my 83 Plymouth Scamp in the salt that I had stored for the winter...
But, I now have a box of 91 V3500 4l80e transfer case makings. Sensor in tail shaft, round style adapter, 32 tooth input. All there, and if not, well, I have a complete nv465 case to pilfer from. The guy cut me a decent deal, $200, I know the adapter alone sells for $275 and it saves me the cost of matching for the reluctor gear.
The FLU farm
1,443
The actual midwest, NM.
Another alternative, which gives you a lower Low range (in this case 3.8:1) and twin sticks, is to use an Atlas transfer case.
I put this 4L80E and Atlas 'case together a while back for a project that never happened, so it's for sale.
And if I sell that setup, then I might as well sell the built 6.5 that it was for, too.
Tried uploading photos, but failed. Sorry.
richingalveston
122
galveston/Texas
ORD normally sells all the different shafts for the 205 if you don't find a used one.
You can use the ORD magnum box as a spacer also. Its a great compact doubler. and it bolts to both the 205 and 4l80e with no other adaptors. It is the adaptor. Not the cheapest way to go because you also need new shifters once you double
Rich
