expeditionnw
- 1
- 18
- Alaska
Its off an MRAP. They have some that are identical without a CTIS valve. It simply unbolts and you screw in a valve stem. They are the wheels used for the deuce adapter plates for super singlesStandard 10 lug (FMTV) pattern, aluminum hutchinson. Built in CTIS valve.
View attachment 715503View attachment 715502View attachment 715501
Any idea what they were used on? Curious what the ctis looked like.I have these and they are a budd bolt pattern and nut centered. Not hub centered like an mrap. I plan on machining a special nut to convert the ctis to work once I get my lathe set up. You could use thes rims with the aluminum rim nuts with no ctis, but the one hole should have a bushing pressed in place to fit proper.
Did you try taking the cap bolts out and taping the valves with a hammer? It looks like they have a very heavy coating on them making them appear to be part of the wheel...Wes, these CTIS do not unbolt. They are cast part of the wheel...
Again, no. Look at my photos. These are lmtv pattern, with a built in Ctis regulator.
Jeez. They are part of the wheel. The internal bits of thevalve can be unbolted but the housing is cast in. They are very slick.Did you try taking the cap bolts out and taping the valves with a hammer? It looks like they have a very heavy coating on them making them appear to be part of the wheel...
Nah... of course does the valve housing come off. Why would they have those two socket cap screws, if not...?.....
Jeez. They are part of the wheel. The internal bits of the valve can be unbolted but the housing is cast in. They are very slick.
Alrighty then... good luck identifying your slick wheels.Again, no. Look at my photos. These are lmtv pattern, with a built in Ctis regulator.
I owe you a public apology. You are correct on all counts, the unit was super crusted on there. I apologize and stand humbly corrected!Alrighty then... good luck identifying your slick wheels.
Hey, don’t sweat it!I owe you a public apology. You are correct on all counts, the unit was super crusted on there. I apologize and stand humbly corrected!
I believe they were used on the MaxxproAny idea what they were used on? Curious what the ctis looked like.
