Dual output pto adapter question of operation
M35a2duece
Eau Claire wisconsin
I currently have an m35a2 with winch. I'd like to add another pto output to send power to a hydraulic pump for a dump box. My question is can the Rear output of the pto add on unit be separatly engaged from the front? Will my winch need to be disengaged before I could use the hydraulic pump ran by the Rear output? Or is There 2 separate engagement levers? Sorry if something already exists describing this. I tried looking but cant even find a picture.
M35a2duece
Thanks! I didn't know there was a rear t case pto. I think I need the Rear output adapter for my current transmission one, or at least I think it's more appropriate since then I won't be able to run the pump backwards as well.
There must be 2 shifter levers for it since text in those threads refrence that they can be shifted independently
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
Yes different shifters. If you look in the TM it will illistrate the parts. You are correct about what you need.
