infidel got me
32
Newberry, Florida
HECK YEAH THEY RIPPED--but I was replacing the balljoints anyway. This one is the first (of course its mine) that I have seen with no grease fittings. The bolts came out easy, it was the lower nut that was hard to hold. The boot was in the way.
Action
1,564
East Tennessee
I cant get a wrench or socket on the bottom of lower because the hub is in the way. I may have larger nuts and bolts, too. The upgraded older and newer use larger hardware on the ball joints. I would use MOOG problem solver for replacements.
jester3798
blairstown, nj
Motor is in, hood is on, shes back on her feet.....
motor is in and running. hood is on. she is back on her feet. some more fabricating and wiring needed. getting closeIMG_2430.jpgIMG_2431.jpg
mdainsd
25
San Diego, CA
Do you have photos / details to share?
I will get photos this weekend. Its a M1025, I started a thread today about it. Mostly all there, rolling, braking, steering. Brand new 6.5 that wont start due to low compression. I have the glow plugs out and a little MMO in each cylinder to see if that has any effect.
florky
Daphne, AL
Added a little bit of thump to the girl.
Added
BOSS AUDIO BASS1600
10 inch 1600-watt Amplified Subwoofer System with Enclosure
Existing - installed last year.
BOSS AUDIO BRRF46
1000 WATTS MAX POWER 46" SIDE x SIDE | AMPLIFIED OVERHEAD SYSTEM Featuring Built-in Class D Amplifier, External BLUETOOTH® Controller and Built-in Dome Lights
