Blown Hub Seal?
Steelreaper80
96
Indianapolis IN
Hey guys, need a lifeline thrown my way. Heading back home from Chicago and stopped at a truck stop for coffee. I got out if the M925A2 and saw my middle drivers side tire was wet.......soaked in gear oil. I am 121 miles out from home. Any suggestions?
What is the issue and what parts will I need? Can I drive it at all at slow speeds? Any help is greatly appreciated!!!
Elijah95
Certified Rookie
1,240
1,215
Georgia
Is it coming from your outer seal there where the bolts attach it to the hub?
Is ctis intact? Whether it functions or not, most certainly you have a clogged axle vent and it put extra pressure on your seals during your long drive, and if the ctis seals are weak or if the outer axle gasket where it bolts together is weak, you’ll get the centrifugal sling of gear oil. Check your gear oil in that axle, and as long as hub temperatures do not exceed 170° limp her home! Carefully touch the hub with the back of your hand briefly
Shouldn’t be any problem getting home. In fact, after you get out, run atleast 20 miles without touching your brakes and try to stop without them, and recheck hub temp. As long as your brake isn’t dragging and melted the seal, then you don’t have to worry about the bearings because gear oil works just fine keeping her lubed. If it’s still about the temp of the other hubs, full speed ahead
Steelreaper80
96
Indianapolis IN
Thank you very much. Topping off gear oil now.
Elijah95
Certified Rookie
1,240
1,215
Georgia
CTIS has been removed. It seems to be dripping from where the CTIS went into the axle. It is not leaking from the outer seal.
There shouldn’t be gear oil coming from that port, if you remove the ctis plug in the hub and oil leaks out, your seals have failed and you need to consider getting rid of your factory military axle vents and using an open vent system with hoses routed higher, then servicing all 4 rear hubs
  • Like
Reactions: HDN
M35A2-AZ
434
Tonopah, AZ
Look would guess it is coming form the wheel hub/ Axle bolts are loose. 10 bolts and take 3/4" wrench
Steelreaper80
96
Indianapolis IN
I managed to get it back. Thanks for all the help. I did find out that my brakes have been dragging on that wheel so I probably fried the hub seals. I have new parts on order including new shoes, seals, and spring brake can bladder. The hub was hot, but not melt your skin off hot. It was just heat from the brakes. You could hold your hand on the hub without burning it. The axle never ran dry of oil and the differential was still full once I got it back to the shop. Do you think that I need new bearings or just re-use the ones I have if they look ok?
Ajax MD
1,435
Mayo, MD
Inspect the bearings visually and spin them in your hand. I found these resources to be useful in assessing the bearings' conditions.
There are two types of axles types- "Dry" and "Wet." The old 809 series were "dry." They used a piece of cork in a keyway to keep the gear oil contained to the differential. The bearings are lubricated by heavy grease. These axles do not have the sealing system necessary to allow the gear oil to lubricate the wheel bearings without leaking out.
Wet axles have the necessary system of seals to allow the gear oil in the differential to flow into the axle tubes, lubricating the wheel bearings. I *think* that all or most of the 900 series trucks have wet axles. If I recall, there is a procedure in the manuals that explains how far to fill the differential and get oil into the axle tubes.
I apologize if you knew all this already.
Steelreaper80
96
Indianapolis IN
Well, pulled the hub Monday, brake shoes looked great, got excited that perhaps it wouldn't be too bad once I pulled the hub....pulled the hub today, outer bearing and seal looked good, got the hub off and the inner bearing literally fell apart into pieces. The bearing metal has welded itself to the shaft housing! Do I need an entirely new hub and how do I get the welded bearing metal off of the axle housing without destroying it? Is the hub beyond a new race and inner bearing? There is also material, which I assume is cooked grease that is in the exact shape of the destroyed bearing. I included photos. Any help is greatly appreciated.
  • Wow
Reactions: HDN
Glenngineer
The M939 A1 and A2 Booth use greased bearings with seals to keep the oil out I believe .that hub may have been assembled incorrectly .You should check if that bearing material made it into the differential. Probably time to look at all the hubs.
simp5782
Feo, Fuerte y Formal
9,506
Mason, TN
There are 2 seals one in the hub one on the inner axle. Doubtful it got past the inner housing seal if you don't have a leak there.
Member suprman used to carry some of the hubs new in the box for cheap.
Glenngineer
That looks like a speedy sleeve may have been used on that ,take a small sharp cold chisel and see if it peals off. As suggested by simp5782 a new one may be your best bet ,your seal surface is pitted and worn .Probably the start of your failure.
Steelreaper80
96
Indianapolis IN
I got the axle housing cleaned up fairly nicely with a Dremel. Not perfect but it is smooth all the way around and "should" be a nice surface for the new seal. I have never seen a bearing that bad. Outer bearing had oil only on it. No grease. I will check the differential oil once bearings and seals get here. I hate to do it but I will probably one at a time pull all the hubs.....ugh
Steelreaper80
96
Indianapolis IN
It was the actual metal of the bearings that welded to the housing. Dremel tool took it off"mostly". It is now smooth all the way around. You can feel slight imperfections in it, I did it by had so it is not machined perfectly but it is close and smooth.
