Source for 5/8-18 thread wheel stud flange nuts?
coachgeo
3,547
North of Cincy OH
So......Yes, I searched this forum, the internet, PM'd ...
... Looks like I need to start justifying my requests...
unfortunately your NOT in the norm to have searched first... thus the reactions. Good number of folk do as you proposed.... "mention that they have done search first..." Wise ones even ask for advice on search terms to use that may help lead them to the answer they seek.
glad folk had enough experience and/or personal archive to step up and help. Agree, kind of them.
ps- working toward putting the supplied sources into google shared parts spreadsheet for the next person. Has someone stepped up and started similar on the 939 or 923 forum? If not there's your next project?
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
Only 1 type of LMTV wheel can fit a 39/809/939 series truck. They are Titan brand. Accurate and Hutchinson brands use the same beadlock nut. However only the Titan is double tapered to allow lug nuts from either side.
LCA078
103
Austin, TX
Nice try but I recommend using the search function before posting a query (as was the advice given to me here). Wes has already done an amazing job of cross-listing most commercially available parts for the M939s in the old 5-ton forum (Mods- please move it and other relevant stickies to the new M939 forum). This link is always my first stop for parts numbers but I didn't see what I needed.
LCA078
103
Austin, TX
That is really good info I did not know. Luckily I bought the Titan ones- thanks!
spankybear
981
WA
[snip] I specially was asking for a source of commercially available 5/8-18 flange nuts....[snip]
McMaster Carr is your friend. You may do better on price (not by much) but there are one stop for most all of your needs. Plus the years I have delt with them they are the best.
LCA078
103
Austin, TX
Like I mentioned before, we have an account with McMaster and they do a great job. They have slipped a bit because now you don't know the shipping costs and delivery until after you 'pay'. I've realized for small, lightweight items (gaskets, o-rings, etc.), it's easier and cheaper to not use them. My last order for $7 worth of washers with integrated o-ring ended up being a $15 charge on my credit card because of the $8 dollars shipping. The nuts I purchased on ebay were same price but had free priority shipping and no tax. Does it matter that much for the few bucks I saved using ebay? Not really but I have issues with 'buying' something then finding out later the unexpected costs in shipping.
Gringel- I respect and appreciate the decision to merge threads but i don't agree on this particular instance. LMTV wheels are also used on the older 5-tons and that's probably where this info is needed most instead of here. Either way is good and I thank you as I know herding us cats on the forums is a thankless job.
simp5782
9,509
Mason, TN
I will note that the parts spreadsheets were designed to list parts that could be readily found locally. I.e. napa, O'Reillys. Not a place where you gotta wait a week for it to show up with the UPS man.
They do not list everything such at bolt/nut sizes cause in a pinch anything will work and a 5/8" fine thread nut can be found at any hardware store to fix it that day. Nor do does it list bolt sizes cause if you don't know bolt sizes by looking at it then you should put the wrench down and go back in the house imo.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
.... if you don't know bolt sizes by looking at it then you should put the wrench down and go back in the house imo.
Ha-ha, that recommendation... that is funny, Wes!:ROFLMAO:
I bet there are not many around here that could tell a 5/16" coarse thread from a M8*1.25; or a 3/8"-16 from a M10*1.5; or a 1/2"-13 (UNC)) from a 1/2"-12 (BSW), to name a few examples - just by looking at them. Even less without holding both, side-by-side.
But yes, I know what you meant with it.... ;)
simp5782
9,509
Mason, TN
I've gotten spoiled G. The 915 doesn't even have fine thread bolts on it. Not too many cuss words being said involving carc paint and fine thread bolts
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
Yeah, times have changed obviously. To think that they used Grade 8 bolts, 3/8"-24 to even hold the wiring harness of a M35 in place...!
TomTime
1,672
MD.
here is a bit of a surprise with the eBay flange nuts (12301125)...100 for $50... they are smaller.
yes the thread is correct BUT the eBay specials are 4mm shorter and 2 mm narrower.. bewareView attachment 846366
FYI.
