MEP-803a help finding the fuse for the FU1 Battery charging circuit for the alternato
mingram
boynton beach, florida
I just got the 803 running but notice that I am not charging the batteries when running. I believe this is related to the Fuse and cap missing from the system. Where can i get a part like this and what type of fuse does it take. I have searched but no luck finding the specifics.
thank in advance
martin
Guyfang
22,201
Burgkunstadt, Germany
Martin,
FUSE, CARTRIDGE 30 AMPS , Part number: F03A125V30A , NSN: 5920-00-539-6920, Figure 8, Item 22.
DO you have the TM's? This info is in the parts manual. If you do not have the TM's, go to the TM section and download them all.
The following info was in the internet.
Overall Length
: 1.250 inches nominal
Body Style: 2A tube type
Continuous Current Rating in Amps: 30.000
mingram
Martin,
Overall Length
this is great thanks any idea where one gets the cap from. Is there a good part supplier? it looks like a bayonet type but mine was missing like the fuse.
on my way to the TM section thanks again, i did not find the parts manual for 803a i do have most of the other manuals. Am i missing something.
m
mingram
m
Okay i found it and can get it on ebay thanks again for your help.
martin
Daybreak
2 Star Admiral
741
Va
Guyfang
22,201
Ok thanks!! just having a heck of a time finding a fuse and holder cap...crazy that the lead times are months to just get a fuse! I may just throw a penny in it.
A penny wont fit.
Below is a list of every part number that gets you the right fuse holder. If you cant find one to work for you, let me know. Call mouser.
000-8007-407 94756
005236 82199
0179946 30874
027505-0000 65597
027577-0001 65597
027601-0001 65597
100908-001 54933
10145208 A486G
1075A 09017
10PV00006-563 A3333
1161-0002 17794
116783 64959
1400-0084 28480
14001791-001 17479
151-0802-001 75102
15470-022 01220
16-039F00M00R00 30331
179946 30874
185337-1 37695
1884827 ITEM 11 03956
1988224 53711
19MS757 1LQK8
200136-000 81413
203000201 34631
203000502 34631
21C1596-39 07482
230-45-004 01205
236260 56232
262367 0F6M5
265-1019-000 13499
265-1086-000 13499
265-1086-000 95104
265-1248-010 13499
265-1248-014 95105
301831-8 0F6M5
308-990071-694 90073
3140157 21340
321P154 44940
339100-01 97525
3413 50423
342001 07342
342012 91637
343-1004P1 3B150
343-1004P1 49956
352-0010-00 80009
352-0010-00 94117
362-0518 71503
368-4856-7 11530
377-160-161 00749
377-160-161 07421
4-FU03 38537
4036689-0701 06845
4134600-010 05869
4134600-10 05869
4134600-44 90536
4134600-44 05869
418271-1 96214
418390-1 96214
4210E143 99872
4226K40P027 97424
44-681 27192
460086 94580
482100 04901
4C4-4 98437
5035-5 05869
5035-5 82577
515003 02594
600368-01 09017
62A86B426-1 10001
6301-1/2-JWZ (820) 71400
634709 96073
634709 36346
7210-6011 15455
73270-01 92878
7441731P001 03538
752849 03956
752849 56232
752849-000 03956
7901127-00 90536
7903480-261 90536
7PM-FH1 21806
801770 19203
801770-00 32345
8176719 18876
851-0802-001 75102
851-5210112-001 29436
861664 56232
875PF0025 A0199
8851719 19203
8987953-1 02734
8987953-1 49671
919-0230-020 13499
972690 96214
A2102 81535
A32049 06845
B100287-47 72181
BAP30 37338
BAP30 57655
C93-436-5 F0114
FD1 75915
FD1 81349
FD1 96906
FHL11U 81349
FHL26G 81349
FHN-26G 81349
FHN26-G1 K7542
FHN2661 71400
FHN26G 02387
FHN26G 84613
FHN26G 96906
FHN26G 71400
FHN26G1 02387
FHN26G1 96906
FHN26G1 71400
FHN26G1 81349
FHN26U 81349
FU10010 80249
G38P13247 94033
G395802-1 06KW9
HKMHR 71400
HKP 73274
HKP 64393
HKP 71400
HKP 81349
HKP-AEJQRW 71400
HKP-BL 10133
HKP-CC 79792
HKP-HJE 71400
HKP-W 71400
HKP0 71400
HKP16-039F00M00R00 30331
HKPEH 71400
HKPEHJKQRWZZ 71400
HKPEHJLQR 71400
HKPEHJLQRAABB 71400
HKPEHJLQRWZZ 71400
HKPELQRW 71400
HKPELQRWZ 71400
HKPELQRWZH 71400
HKPHBL 71400
HKPHJLQRWZ 71400
HKPHJLRW 71400
HKPHJQLW 71400
HKPHLAA 71400
HKPHWR 71400
HKPJE 71400
HKPJRWAABBZZ 71400
HKPQRV 71400
HKPZEQ 71400
HKPZEQR 71400
K844027SUB10PT2 49671
KS5842L02 06KW9
MA949 00426
MIL-F-19207-16 81349
MIL-F-19207-16C 81349
MIL-PRF-19207/16 81349
NA0236260 53711
P320A1073 00798
RE-31360 ITEM 11 04034
RE-36572 ITEM 11 04034
RE-54660 ITEM 11 04034
S138-5601 48294
S138-5601 54418
S138-5634 09150
S138-5634 48294
SM-B-189679 80063
SMD571001-55 91417
TS101P02 81349
Below listed is Tech info.
AAFZBODY MATERIALPLASTIC, DIALLYL PHTHALATE, MIL-M-14, TYPE SDG AND PLASTIC, DIALLYL PHTHALATE, MIL-M-19833, TYPE GDI-30F
AAQLBODY STYLEBUSHING MOUNTED TYPE
ABDNTERMINAL SURFACE TREATMENTSOLDER DIP AND TIN PLATED
ABHPOVERALL LENGTH2 313/1000 INCHES NOMINAL
ABKHBUSHING DIAMETER0 1/2 INCHES NOMINAL
ABTJMOUNTING HOLE QUANTITY1
ADAVOVERALL DIAMETER0 86/125 INCHES NOMINAL
ADZCENVIRONMENTAL PROTECTIONDRIPPROOF
AEVBMOUNTING HOLE STYLEBUSHING MOUNTING
AFJNFRAGILITY FACTORMODERATELY RUGGED
AFRGCONTACT MATERIALANY ACCEPTABLE
AFRHCONTACT SURFACE TREATMENTANY ACCEPTABLE
AGUEIII FUSE ACCOMMODATION QUANTITY1
AGUJACCOMMODATED FUSE LENGTH1 1/4 INCHES NOMINAL
AGUKACCOMMODATED FERRULE DIAMETER0 1/4 INCHES NOMINAL
AGUTLENGTH FROM FRONT PROTRUSION TO MOUNTING SURFACE0 3/4 INCHES NOMINAL
AGUUBUSHING THREAD LENGTH0 1/2 INCHES NOMINAL
AGUVCAP DIAMETER0 17/25 INCHES MINIMUM AND 69/100 INCHES MAXIMUM
AGVFBUSHING HOLE DIAMETER0 1/2 INCHES MINIMUM AND 51/100 INCHES MAXIMUM
AGVHFLATTED SIDE BUSHING HOLE LENGTH0 117/250 INCHES MINIMUM AND 239/500 INCHES MAXIMUM
CQJLCURRENT CARRYING RATING IN AMPS30
CSNMFUSE TERMINAL TYPE ACCOMMODATEDFERRULE
ELECVOLTAGE IN VOLTS250
TESTTEST DATA DOCUMENT81349-MIL-F-19207 SPECIFICATION (INCLUDES ENGINEERING TYPE BULLETINS, BROCHURES,ETC., THAT REFLECT SPECIFICATION TYPE DATA IN SPECIFICATION FORMAT; EXCLUDES COMMERCIAL CATALOGS, INDUSTRY DIRECTORIES, AND SIMILAR TRADE PUBLICATIONS, REFLECTING GENERAL TYPE DATA ON CERTAIN ENVIRONMENTAL AND PERFORMANCE REQUIREMENTS AND TEST CONDITIONS THAT ARE SHOWN AS "TYPICAL", "AVERAGE", "NOMINAL", ETC.).
TTQYTERMINAL TYPE AND QUANTITY2 TAB, SOLDER LUG
ZZZKSPECIFICATION/STANDARD DATA81349-MIL-F-19207/16 GOVERNMENT SPECIFICATION
WWRD99
1,375
York Pa
Ill look through my parts stash, I might have a cap...
Thanks a bunch!! crazy that something so simple for a part can be such a pain to find...even the fuse is one of those have to buy 30 to get anyone local to order one...no one carries a 30 amp 125 volt fuse.
WWRD99
1,375
York Pa
A penny wont fit.
000-8007-407 94756
005236 82199
0179946 30874
027505-0000 65597
027577-0001 65597
027601-0001 65597
100908-001 54933
10145208 A486G
1075A 09017
10PV00006-563 A3333
1161-0002 17794
116783 64959
1400-0084 28480
14001791-001 17479
151-0802-001 75102
15470-022 01220
179946 30874
185337-1 37695
1988224 53711
19MS757 1LQK8
200136-000 81413
203000201 34631
203000502 34631
21C1596-39 07482
230-45-004 01205
236260 56232
262367 0F6M5
265-1019-000 13499
265-1086-000 13499
265-1086-000 95104
265-1248-010 13499
265-1248-014 95105
301831-8 0F6M5
3140157 21340
321P154 44940
339100-01 97525
3413 50423
342001 07342
342012 91637
343-1004P1 3B150
343-1004P1 49956
352-0010-00 80009
352-0010-00 94117
362-0518 71503
368-4856-7 11530
377-160-161 00749
377-160-161 07421
4-FU03 38537
4036689-0701 06845
4134600-010 05869
4134600-10 05869
4134600-44 90536
4134600-44 05869
418271-1 96214
418390-1 96214
4210E143 99872
4226K40P027 97424
44-681 27192
460086 94580
482100 04901
4C4-4 98437
5035-5 05869
5035-5 82577
515003 02594
600368-01 09017
62A86B426-1 10001
634709 96073
634709 36346
7210-6011 15455
73270-01 92878
7441731P001 03538
752849 03956
752849 56232
752849-000 03956
7901127-00 90536
7903480-261 90536
7PM-FH1 21806
801770 19203
801770-00 32345
8176719 18876
851-0802-001 75102
861664 56232
875PF0025 A0199
8851719 19203
8987953-1 02734
8987953-1 49671
919-0230-020 13499
972690 96214
A2102 81535
A32049 06845
B100287-47 72181
BAP30 37338
BAP30 57655
C93-436-5 F0114
FD1 75915
FD1 81349
FD1 96906
FHL11U 81349
FHL26G 81349
FHN-26G 81349
FHN26-G1 K7542
FHN2661 71400
FHN26G 02387
FHN26G 84613
FHN26G 96906
FHN26G 71400
FHN26G1 02387
FHN26G1 96906
FHN26G1 71400
FHN26G1 81349
FHN26U 81349
FU10010 80249
G38P13247 94033
G395802-1 06KW9
HKMHR 71400
HKP 73274
HKP 64393
HKP 71400
HKP 81349
HKP-AEJQRW 71400
HKP-BL 10133
HKP-CC 79792
HKP-HJE 71400
HKP-W 71400
HKP0 71400
HKPEH 71400
HKPEHJKQRWZZ 71400
HKPEHJLQR 71400
HKPEHJLQRAABB 71400
HKPEHJLQRWZZ 71400
HKPELQRW 71400
HKPELQRWZ 71400
HKPELQRWZH 71400
HKPHBL 71400
HKPHJLQRWZ 71400
HKPHJLRW 71400
HKPHJQLW 71400
HKPHLAA 71400
HKPHWR 71400
HKPJE 71400
HKPJRWAABBZZ 71400
HKPQRV 71400
HKPZEQ 71400
HKPZEQR 71400
KS5842L02 06KW9
MA949 00426
NA0236260 53711
P320A1073 00798
S138-5601 48294
S138-5601 54418
S138-5634 09150
S138-5634 48294
SM-B-189679 80063
SMD571001-55 91417
TS101P02 81349
FHN26G1
Bussmann / Eaton Logo
Bussmann / Eaton FHN26G1 Enlarge
Images are for reference only
See Product Specifications
Mouser #:
504-FHN26G1
Mfr. #:
FHN26G1
Mfr.:
Bussmann / Eaton
Customer #:
Description:
Fuse Holder MILITARY FUSEHOLDER
Datasheet:
FHN26G1 Datasheet (PDF)
ECAD Model:
FHN26G1 ECAD Model
Download the free Library Loader to convert this file for your ECAD Tool. Learn More.
Compare Product
Add To Project | Add Notes
Availability
Stock:
On Order:
78
Expected 8/17/2020
30
Expected 12/18/2020
Factory Lead-Time:
30
Weeks
This is right off mousers site....the fuse holder out of the manual part number is not in stock until mid august...30 week lead time from the factory....the numbers on the list you have go to request a quote site for the same part...no one has it...0 stock anywhere.
Daybreak
2 Star Admiral
741
Va
Howdy,
And if you drop that part number on ebay.... in stock, and lots cheaper.
fuse = F03A125V30A
Holder assembly = BUSSMANN FHN26G1
Light in the Dark
5,143
MA
Good call Daybreak. Use the phrase 'NEW BUSSMANN FHN26G1 FUSE HOLDER ' and you will see the ad for $8.75 with free shipping.
WWRD99
1,375
York Pa
Dang....didn't know bussman was the buzz word to find it...I had the part number...I do find locating some parts can be a pain...I looked them up in the manual....I ordered the 8.75 one on ebay...excited to get this making power...should have it Wednesday! Thanks a ton!!
Guyfang
22,201
Actually, BUSSMAN is NOT the buzz word. The buzz word is FHN26G1. That's why I put all the part numbers in the thread. You simply have to try a few part numbers or NSN's to see what pops up. Its the same with the fuse.
