TOM R
- 94
- 28
- sewell n.j.
Dimensions please lolI made a sweet looking light bar too CHEAP.
100% agreedThat looks great, I figured that what it will cost me also just haven't got to it, far cry from the 1200+ shipping guys ask for them lol
It looks great! If it wasn't such a long drive, I'd take you up on that steak and beer!100% agreed
I believe the most costly component I bought was this the hinge
Well worth it IMHO, used same one for other jeep tire carriers I previously built. I liked this one cause the length of the shaft allowed me to hole saw drill straight through the c-channel and weld basically in 4 areas.....top/bottom and top/bottom where it comes through both sides of the C-channel therefore I didn't add the gussets to the shaft (albeit all cause I'm just lazy though, it definitely would have added strength)
Grabbed the rachet jack from tractor supply for $50. About $50 from eBay for the bumper rest bracket (again was just lazy and didn't want to build that and figured I could use that as a guide or template on how the rest of the carrier should be laid out. And I think I spent about $80 at the local metal supply yard. Was happy cause they even flame cut me the circle for the wheel mount.
So if you have a welder, chop saw/angle grinder and drill you are set!!
Again I owe Andyrv6av8r a steak dinner and some![]()
I'm originally from Charlotte....next time I'm in town I'll have to hit you upIt looks great! If it wasn't such a long drive, I'd take you up on that steak and beer!
This is awesome, thank you! I had the same idea, these dimensions will be a huge help.Here's a quick dimension sketch. I have several other photos to post if I can get my emails to go through.
View attachment 796862View attachment 796863View attachment 796864
The 9" right triangle will give you the angle. I basically just centered the tire on the tailgate and it came out fine. There's plenty of room on the screw jack, even if you're on a hill.This is awesome, thank you! I had the same idea, these dimensions will be a huge help.
How much spare length do you have on your ratchet? The 8-9” throw made me wonder
Do you recall what this angle was?
Ahh duh I didn’t notice that 21” mark.The 9" right triangle will give you the angle. I basically just centered the tire on the tailgate and it came out fine. There's plenty of room on the screw jack, even if you're on a hill.
It's just a piece of regular 6" C channel like your drawing. I didn't have a tire carrier to measure from either; I looked at photos and just measured what I had and made it work.Ahh duh I didn’t notice that 21” mark.
So did you get your measurements from the OEM carrier?
Where did you find C channel like that? I’ve only ever seen it with this profile:https://www.metalsdepot.com/assets/files/Catalog_Photos/MetalsDepot-channel.jpg
I like how yours keeps the tire tucked in tight to the tailgate. I was going to do my best with that also. Great job.
