- 673
- 895
- 93
- SW Va, Roanoke County
Unless your is badly bent, the one on my truck and the spare both have a bend in them. Are they bad? You got me thinking now!By the way, anyone have a straight drag link laying around, 24P Figure 160, I 1. don't care about the rod ends. I am sure mine is slightly bent.
Tires are finally done.. found both run flats incorrectly positioned, put 24 oz of balancing beads in, we shall see how it does.. now I can move back to the pump,,with no excuses.
.Some more goodies inbound
Sun visors NOS Search FLEE BUY LMTV FMTV M1078 NOS SUN VISOR KIT UP GRADE KIT
5 GANG Switch Array search FLEE BUY 5 Gang Rocker Dual USB Charger +Digital Volmeter +12V Outlet Switch Panel for RV
MRAP mirrors w /DETENT adjusters.. Search FLEE BUY Military Mirror West Coast Style, Left, On Bracket, New MRAP, Universal Set of 2
Midland Valve Rebuild Search FLEE BUY KN34101 MIDLAND VALVE PARTS KIT RRN31BC RN31BA
Air BRake Relay Valve repair kit Search FLEE BUY FMTV M1078 M1083 Air Brake Relay Valve Repair Kit 12417375-001 2530-01-478-5902
Propane Instant Hot Water Search ZoNaMa 6L 12KW Portable Tankless Hot Water Heater 2 GPM RV's & Campers Propane Gas LPG
I have 2 NOS tie rods and good used takeouts in central NCWent for a 500 mile round trip to the mountains and surrounding areas of the Allegheny Highlands, even a little 2 mile off road run (collecting trail cams)
Trans shifts very nice, still have a 4 to 5 hard shift, but its not as harsh as it was. I am going to try another relearn.
It was nice to be able to drive 60MPH on 81 and 220, the 2 new front tires and balancing beads are doing amazing. I think my rear tires have a problem that warrants further investigation now that I have eliminated the fronts
I was able to adjust the bent tie rod enough to get me close to aligned. (still looking for a new one) if someone has the rod laying about don't care about the joints.
Temps on the hubs and differentials seem to be reasonable to the touch, however, that may be my next service item.
A long day behind the wheel of ReisTB without incident is a great day in my MV book
Great Day, the better half picked up one of these for those just in case days.. very cool little GENSET, quiet, good price and as often as I might need it, fits the bill perfectly.
ANd you know that space right behind the rear fender and tail light.. nice little pull out box is in the future
May convert it to LPG someday
Mmmmmmmm, Harbor Freight.Great Day, the better half picked up one of these for those just in case days.. very cool little GENSET, quiet, good price and as often as I might need it, fits the bill perfectly.
My neighbor has that one and it is quiet!Great Day, the better half picked up one of these for those just in case days.. very cool little GENSET, quiet, good price and as often as I might need it, fits the bill perfectly.
 www.samsclub.com
					www.samsclub.com
