turnerman
- 56
- 18
- landrum, sc
years ago I installed a mk17a1 palfanger crane on a deuce chassis with a pto run hydraulic pump. It has served me well except for cold weather days when the oil is cold it will strip the teeth off the pto shaft in the transmission. The hydraulic pump probably pulls 50 hp. Yep you guessed it I forgot to warm the oil up and ruined my trans again but this time where did all the parts go? Now my options seem to be fix stripped gear if can find it, change the transmission to a 5 ton transmission and pto, or find a transfer case pto. Anybody have any leads? I would love the higher hp transfer case pto but I could buy a truck for what they want for the coupling. What do You guys think? Anyone know where I can find the pto gear? Thanks
