Winch install question/issue
Guruman
Not so new member
1,074
Cody, Wyoming
Maybe this pic is misleading...
I cut off the three hole flange and welded up a new four hole one to match the frame, being careful to keep the same angle as the old flange.
Now I'm not sure if it is supposed to angle up or down. This pic looks more horizontal to me.
I get mine in place and if I angle it down it looks too low compared to where the line exits the top of the drum. And if I angle it up it seems pretty close to the inside if the tire.
Is this pic just an optical illusion?
Ronmar
7,996
Port angeles wa
Either this guide is to push/pull the cable to a certain position to get it to clear an obstruction, or it is there to keep it from sagging. At any rate, I would try and position it so it keeps the cable as close as possible to its tensioned line of travel.
If it is pushing the cable out of line to clear some obstruction I would make sure the strut is as close to being in the same plane as the cable so the force applied to it is directly back along the strut(pushing/compression) to tge frame and not at an angle to the strut(bending/shear).
Guruman
Not so new member
1,074
Cody, Wyoming
I think it's to keep the cable from sagging and cutting into the air lines at that rear wheel, which make me think it should run up. Also, the rear fairlead is higher. "Up" it is.
coachgeo
3,480
North of Cincy OH
yup. finish everything else. Get winch working. Pull a load so cable is tight on something then fit that piece up accordingly and mark well. THen do again but winch pull in opposite direction and repeat... mark well in some different way. then slacken off the winch... pull cable way out of way .. cover it up to keep drilling shards off of it... then drill at some compromise between the two sets of drawn holes and mount. Just a guess though.. I ain't no fabrakater
Guruman
Not so new member
1,074
Cody, Wyoming
So... here's what 500 feet of Dyneema winch line looks like in the box. Once I get the wiring in place, I hope to get this all swapped onto the drum.
Not sure it'll take all 500 feet, but having some extra to splice up some rigging lines is not a bad thing.
20,504
I see that Inspector Dog is verifying the quality of your new winch rope... :)
Guruman
Not so new member
1,074
Cody, Wyoming
That's my bodyguard, Luka, a 4 year old Belgian Malanois trained in executive protection by Dallas K9. She knows about 30 different commands, including separate commands for "grab that guy", "bite that guy" and "kill that guy". She's even been trained to take cover when the shooting starts. She'll do anything I want, as long as I can communicate it to her.
GeneralDisorder
5,833
Portland, OR
Nothing like a trained dog or pack of them to discourage unwanted aggression. My shepherds (2) ride shotgun in my LMTV and I have no worries about it's safety. The imposing nature of the machine and two unfriendly canines in the cab deter all interest in my experience. The dogs are big babies in reality but they have a ferocious bark that sends unwanted attention down the road.
Guruman
Not so new member
1,074
Cody, Wyoming
Kind of off the topic of the thread here, but how do you get your dog into and out of the cab? I'm trying to come up with some kind of ramp that's not too much hassle.
Luka can make it into and out of the cab if I ask her, but I'm afraid that someday she'll make misstep and hurt herself trying. Also, my wife has a standard schnauzer that could not make the jump.
GeneralDisorder
5,833
Portland, OR
The little one is a 40 lb Shepherd mix (German and Miniature) and she can jump in with no real issue. Sometimes she misses but she always gets it on the second try. She is 2 years old.
The big guy is about 75 lbs and he is 1/4 Australian shepherd. He initially tried jumping in but failed too many times so he doesn't attempt it anymore. He stands with his paws on the step and I lift his back legs. That's turned out to be the easiest way. He is 5 years old. He's very strong and lean but he just can't quite get up there - too big to jump that high and not big enough to reach at the same time I guess. The little one is absolutely spring loaded - she learned to dance on her hind legs for treats from the other half's 8 lb dust mop.
They can both jump down no problem. If they get too old to get in and out of the cab I suppose they will have to ride in the back of the 1079 till they can't climb the stairs......
Third From Texas
6,643
Corpus Christi Texas
I've probably shown you this before.
I took a standard folding dog ramp (my neighbors actually gave it to me after their dog wouldn't use it) and I added a piece of angle iron to the top edge. Then on the truck I bolted a strip of 1' flat stock shimmed out 1/4" with standoffs. The angle iron slips into the slot and secures the ramp.
When not in use it can fold and stow in the passenger side floor with a bungee cord holding it to the dash/kick panel.
I went this route because I've had GSDs before and anything I can do to protect her hips gets done. I use it for her to disembark as well (although she'd really rather try and jump because she says dad takes too long setting up the ramp, LOL).
Guruman
Not so new member
1,074
Cody, Wyoming
That's a great idea @Third From Texas. and easier than what I had in mind.
I was kind of planning on something that went all the way to the footwell height, which means a very long and heavy ramp.
Going only to the top of the step is much easier to accomplish with a smaller ramp. And I could probably fab up some kind of rack/mount I the space underneath the passenger rear window there somehow.
Nice work, and thanks for the great idea.
Replace that angle iron with some piano hinge and get that folding action just right with an air or electric actuator, and I wouldn't need steps at all.......
chucky
19,244
TN .
When not in use it can fold and stow in the passenger side floor with a bungee cord holding it to the dash/power panel.
Dam Chester !!!!! Slides now ! Whats next pony rides and clowns STRANGER DANGER STRANGER DANGER !!!!!!! New rule if they want to play on the slide you need to check I.D.
coachgeo
3,480
North of Cincy OH
lol.... there is not a question/discussion one can think of that has not been brought up before.
Guruman
Not so new member
1,074
Cody, Wyoming
Finally got everything in place, all wired and plumbed in, but the winch does not turn.
The PTO light coms on when I flip the switch and I had a couple leaking connections, so I think the PTO is working.
I cannot tell if anything happens when turning on the winch switch ( I tried it in both positions as there's not really an indicator of which way is "on")
When pressing the winch in or out button nothing noticeable happens in either direction.
I suspect either the winch power is not working or the spool valve in the rear has crapped out.
MrMikey4026
417
Eatonville Washington
Make sure the PTO ground wire is attached to one of the bolts on the PTO solenoid cover.
It was the only place I could attach the ground that would work. Colt had the same problem when he installed his winch. The entire PTO is metal, so don't ask me why?
You should be able to hear the PTO/pump of it running.
Also check the ground for the valve assembly.
Guruman
Not so new member
1,074
Cody, Wyoming
Tore back into this today.... Slapped a voltmeter o the output wires under the passenger kick panel..... no voltage when applying the switch. Took the switch panel off to find that I have the winch enable and the winch in/out switches reversed. Either swapped the plugs or go the switches in the wrong holes... not sure which.
Anyway. The drum is turning now.... but it did puke a bit of oil out the inside of the drum (up against the frame. Not sure what that's all about. Hopefully I don't have to take the winch apart.
Guruman
Not so new member
1,074
Cody, Wyoming
Back at it today. Got the wireless remote wired up.
It wasn't until I got the remote working that I realized my winch will power in, but not out.
Verified I was getting power to the plug under the passenger dash, so either I have a broken wire, or the solenoid din connector, or the solenoid is bad.
Anyone know offhand which din connector these use?
McMaster-Carr lists several styles, and different spacings...
If the DIN connector doesn't make it work, maybe the whole assembly could be replaced.... seems like should be standard hydraulic stuff.... McMaster-Carr lists some of these too, with different ports open and such.... not sure what it would take to just replace the whole shebang.
