35” Tires
Kruzer022
Oregon
Shopping for new tires. Pretty significant price difference between 37’s and 35’s. Anyone running 35x12.50’s on their HMMWV? Pics? I have a set of 18” rims they’ll be going on.
Coug
4,732
Olympia/WA
I don't think I've heard of anyone using smaller tires. Usually it's people asking how big they can go.
87cr250r
2,116
Rodeo, Ca
Yokohama has decent prices on 37x12.5-17 tires. I'm not a HMMWV guy but where did the 18" rim size come from? It seems like you're shooting yourself in the foot with an odd ball wheel. I believe I paid $1700 for 5 tires in 37 on 17 inch rims.
simp5782
Feo, Fuerte y Formal
9,506
Mason, TN
18s arent too oddball. They come on most newer Ford and GM pickups. Tires are cheap. My 1 ton runs a mud terrain 35x12.50R18s that were only $250 each
MarkM
1,147
2,096
WOBURN. MA.
35s on the HMMWV will slow down your highway speed by like 4mph. Not desirable in my opinion.
Mark
Hummer Guy
823
United States Louisiana
I'm lucky to do 70 in mines with the 4 speed, although I have a big blocky top on the back that increases drag by quite a bit. I'm thinking about going with 40s next to increase the top speed a little. I already have a 2 inch suspension lift in the corner that's waiting to be installed
Kruzer022
Oregon
They’re off a Ram 2500. 18” isn’t oddball for 35” tires, but apparently is for 37” tires
simp5782
9,506
Mason, TN
Yes 37s aren't common for 18s. They become a flotation tire in 37s with 18in wheels and become 8 ply too.
Least with 35s you can get 12plys.
Mogman
10,457
Papalote, TX
The wheels off a Ram will not have the correct offset, you pretty much must stick with HMMWV wheels or aftermarket wheels with the correct HMMWV offset, why there are so few viable choices.
Mogman
10,457
Papalote, TX
Taller tires will not give you a higher top speed if drag is limiting you, in fact it will likely go slower as the lack of power is multiplied
rjf189
102
33
Arlington, VA
You could really save some money if you go down to 31s, which shouldn't look much more out of place than 35s. :cool:
TOBASH
3,924
Brooklyn, NY
Go cart tires. Top end might be affected but man will he be quick off the line!
:doh:
I suggest not doing things that are off the reservation. Stick with 16.5 by 37 or purchase H2 rims, have the centers expanded, and purchase less expensive tires that way. A set of H2 rims should not cost more than $600
