AMMPS 5/10/15KW Starter Source
Light in the Dark
6,717
MA
Starting doing some snooping around for a source on these (spurred by a Parts Wanted posting). Cummins wants almost $900 for their NSN for this item... I know for a fact that its a buy-in for them (and of course if you know how to scour the web by NSN, you can ascertain certain manufacturers numbers for items).
So here is the baseline on the part:
Well 11.131.457 AZE6604 comes back to a MAHLE (who I guess owns Iskra) IS1234 (which is only a slight variation of the second Iskra item number).
Further snooping leads me here: http://www.letrika.mahle.com/katalog/letrikaletrika.html?lang=E&koda=IS1234
Well wouldn't you know, that item number comes back to MAHLE P/N MS 251
You can pick that starter up (seemingly) new at Summit Racing for $285 - https://www.summitracing.com/parts/mah-ms251
Feel free to double check my work, but that appears to be the identical starter folks may need in the future. Hope this helps someone in the future.
peapvp
1,534
Basehor, KS
You can check here on the German Mahle Website:
MS251
best viewed on a PC
They listed the explosion drawings - you should be able to get the parts you need from Mahle direct to repair your starter
they also provide an explanation in German of why your starter is twisted:
Prost Mahlzeit :beer:
FarmingSmallKubota
1,337
Wapakoneta, Ohio
MS251
best viewed on a PC
If you scroll it does have an english version so i was able to read the explanation. I guess i will be looking at the TM for a RELAY to make sure thats not faulty before fixing or putting in a new starter.
peapvp
1,534
Basehor, KS
I am on iPhone at the moment. That’s why I suggested to use a PC
As to the relay, on the AMMPS 10x0 this is controlled by ECS through Start / Stop / Switch and MPU
If the MPU / ECS is faulty, then Starter stays engaged and will twist
Welcome to the world of AMMPS
