802a no start from switch and no power at lugs.
aredman
24
13
Indiana
Here is a diagram that ought to speed finding out why K2 isn't operating from S1.
The blue box's indicate the base wire number for each wire.
The red numbers in the yellow box's indicate the terminal on each component that the wire is connected to.
Not shown is actual path from S7-2 to K2-X1.
Here is the actual path for that....
S7-2 ------------TB5-20 -------------------- J6-20 / P6-20 -------------- K2-X1
Simply probe along the path with S1 in START to determine where you losing the 24 volts to K2-X1
I got power at terminal 9 on K16. Not sure where to look after that. K16 doesn’t physically move.
kloppk
4,198
Massachusetts
If all is working properly you should have 24 volts at K16 terminal 6 with the set NOT running and S1 in START assuming there are no fault lights illuminated.
If there are NO fault lights AND you move S1 from OFF to PRIME/Run and back you should see K16 move. If it doesn't then S14 is the next suspect.
** corrected
aredman
24
13
Indiana
If all is working properly you should have 24 volts at K16 terminal 6 with the set NOT running and S1 in Prime/Run assuming there are no fault lights illuminated.
Meant to say I get 24 volts at terminal 9 when I put in start position.
kloppk
4,198
Massachusetts
I corrected my previous post.
TomTime
1,672
MD.
The pages I mentioned yesterday...
If anyone wants the two PDF files with the info below feel free to shoot me a PM with your email address. - Kurt
I can also send a Excel spreadsheet of the wiring for the 802A/803A. It lists component to component wiring and wire number to component. It has two tabs.
It's something that @Guyfang and I worked on a few years ago to come up with a hopefully accurate Excel file depicting the wiring. Useful for troubleshooting!
PM sent.
Thanks,
Tom.
aredman
24
13
Indiana
Well maybe dumb question, am I suppose to be testing at actual terminals on relay or wires with Phillips screws.
