MEP 1040 3661- maintanance Item Active
Duffysguns
9
Maryland
Warning 3661 came on indicating first service due in the next 25 hours. I do not use the unit all that often so may be some time before I hit that mark. Problem I have is I can't turn the warning off have gone through the maintenance section on the control panel and this 3661 does not come up. With a warning action activated the screen does not shut down after turning off the generator which then kills the battery s. my temporary fix has been to disconnect the battery's for 30 seconds and the screen shuts down and start up goes correctly but the warning 3661 is still on. Any ideas on the procedure to clear the warning much appreciated.
kloppk
4,213
Massachusetts
According to the -10 TM page 0005-30 it looks like you can "dismiss", "defer" or "complete" the maintenance item(s) for that fault.
genman
chipley
I did the procedure and i cannot get the warning to go away or screen shutdown.I have to remove the battery cable to prevent the discharge of the battery.
FarmingSmallKubota
1,399
Wapakoneta, Ohio
So if you hit clear it does not go away? Unit should power off on its own. there is a countdown after you shut it off. Does your disconnect to the right of your batteries not work?
jonlinds
Jacksonville Fl
I have went through the process and you can only cancel or “complete”. I have tried to clear the code with complete and it does not clear. Make sense?
jonlinds
Jacksonville Fl
You have to clear every single maintenance item in the maintenance screen. The most we ever had were 20 items and each one had to be cleared individually before the 3661 warning can be reset
Okay that’s what I did not do. Will try that when I get back to it next week. Will update then. Thanks!
