How does dual switch brake pedal work ?
Mogman
10,254
Papalote, TX
Dear Mogman, first I really appreciate your help. I have just disconnected both batteries entirely. Went to the TCU - jump-wired (A) and (E). Reconnected the batteries. Flipped the ignition switch to check the transmission codes.....
Again nothing. I'll attach a video, unless I'm missinterpreting it.....
If you disconnect the batteries you will erase the codes, you would need to drive it again enough to cause it to go into limp mode and then try again without disconnecting the batteries.
Mastherr
Miami
I thought it was an instruction to do so!!!!!
…so what’s next ? Drive around for while until the codes are recorded again if any?
Mogman
10,254
Papalote, TX
Does the trans light come on when switched to run and then go off when started?
TOBASH
3,853
Brooklyn, NY
Perhaps I misunderstanding you, but you disconnected the batteries and then went to check transmission codes? There would be no power going to the transmission, therefore no codes. You need to disconnect the batteries and then reconnect the batteries and then disconnect the temperature control module and then remove the G2 cover, which is the accessory area and jumper A and E. Then watch the codes. It starts with a code 12, continues with the code 12, then you get a bunch of codes and then it ends with a code 12.
Mogman
10,254
Papalote, TX
If you disconnect the batteries the codes will be erased.
Mastherr
Miami
Hi Tobash, thanks for jumping in. I've disconnected the batteries for about 5 minutes, reconnected them, and went to do the testing. Removed, the cap, jump wired (A) and (E), Ignition on (not engine running), and transmission light begin the testing. Only 3 times code 12, a "lenghty" time no code, and again 3 times code 12.......
I don't know about "disconnect the temperature control module ", never heard about this procedure. What is it?
In the picture attached, is this the temperature control module I have to disconnect prior doing the transmission code testing? If not, please help me identify it.
Many tks
Mogman
10,254
Papalote, TX
Many tks
Any time you are doing electrical work where you are going from off to run repeatedly you should disconnect the TSU or you can burn up the glow plugs.
Any time the TSU is plugged in and you turn the run switch to off you MUST wait at least 90 second before going back to run.
All this is laid out in the transmission supplement and the -10 operators manual which should be mandatory reading for anyone before they touch a HMMWV
Mastherr
Miami
Ok, will disconnect temp control next time.
Question: should I drive around in limp mode so new codes are stored again for future reading? Any idea for how long should I drive for the system to eventually record faulty codes again?
Mogman
10,254
Papalote, TX
It should not take long, IIRC it would shift one time, if so I predict you should see a code 87
Mastherr
Miami
Dear TOBASH, Mogman and Mullaney, after the misunderstanding, reconnected the batteries went for a 30 minutes spin around the block (during the spin I "forced" it, went to almost 3,500RPM, changed High/Low gears, etc....), parked, turned it off, unplugged the glow plugs TSU, jump wired "A" and "E", turned ignition on (not started) and recorded the transmission light codes. Nothing!!! only 12 12 12 12 12 12 12 ......
HMMWV remains in limp mode with no transmission error whatsoever! The only unusual thing it the break warning light ALWAYS on! ..
can you shed any light at this tunnel?
Mogman
10,254
Papalote, TX
If the trans light comes on when switched to run then goes out when you start the truck then I would suggest trying another TCM, it sees the truck running but does not know it has problems.
Retiredwarhorses
4,464
Brentwood, Calif
The way I see it, the vehicle is on "limp mode"! No transmission codes!... The only other visible clue is the break warning light (Red) always on.... Could this be the troubleshooting route to follow?
you don’t get codes on a dead TCM…or in some cases,open the TCM encl and see if there is even a TCM inside.
Mastherr
Miami
Yes, the light comes on, goes off and the truck starts perfectly.
Before spending $600-700 on a new TCM, is there any testing (electronically speaking) I could do ?
Are there other cheaper sensors that might be worth replacing before the TCM itself?
(i.e. swapping TISS for TOSS …)
Mogman
10,254
Papalote, TX
If there was a problem with the sensors and the TCM was healthy enough to know you would get codes.
It would be interesting to disconnect the TISS, TOSS and TPS separately and see if you get any codes
Mastherr
Miami
…good idea, will do that. It will validate if the TCM is working on not! Tks
