Just won an auction - M1088A1
GeneralDisorder
5,822
Portland, OR
Wow. Have not encountered that. Can you disassemble and inspect/post pics of the adjuster? Would like to understand this failure.
Some of mine were pretty UGLY with rust and failed seals but it all functioned fine after cleaning, lubing and adjusting. Let me find that pic.......
Ronmar
7,991
Port angeles wa
Well the adjusters only cycle when the actuators cycle the brakes… That sounds weird… is the drum out of round? Take the wheel off, put on some lugs to hold the drum in proper position and spin it...
GeneralDisorder
5,822
Portland, OR
Perhaps the threads are messed up allowing it to slip out but not back in due to a non-axial force.
Ronmar
7,991
Port angeles wa
If I recall, the spring loaded teeth(with sawtooth serrated faces) are pushed out of the way and ride over the spiral sawtooth grooves on the plunger as the plungers travel outward(pushed by the wedges) because the two sets of sawtooth ridges meet angle to angle(like teeth on a ratchet). Then as the brakes retract and the plungers slide inward, the saw tooth grooves on the plunger and the adjuster teeth ridges engage vertical to vertical(again like teeth on a ratchet), which forces the plunger to rotate and add a small turn to the adjuster screw which is held by the manual adjusters on the end. So the plunger assembly gets a little longer with each brake application…
i seem to recall it being possible to install the teeth incorrectly so the angles and flats did not line up correctly and would not engage properly to cause the above action, disabeling the auto adjuster, so brakes would get looser and looser.
that and damaged manual adjusters would probably only show up after driving a bit though, and it does not sound as if it has been really driven since the brake job? So locking as you roll It out of the bay after work points me back to a out of round drum? You set the shoe spacing on the wide part of the drum and as it rotated to the narrow axis, it engages the shoes?
dwlindsey
81
California
I put the adjuster in a vice and spun it with a pair of channel locks. There were a couple of tough to turn spots, which got better as I worked it. It's behaving well, I think. I'm not sure I trust it enough to re-install it.
I can't explain what happened, I'm sure I had it adjusted correctly yesterday and it was fully extended today.
dwlindsey
81
California
If I recall, the spring loaded teeth(with sawtooth serrated faces) are pushed out of the way and ride over the spiral s it It does not sound as if it has been really driven since the brake job? So locking as you roll It out of the bay after work points me back to a out of round drum? You set the shoe spacing on the wide part of the drum and as it rotated to the narrow axis, it engages the shoes?
Correct. I adjusted the brakes yesterday and tried to back it out of the garage today.
I set the shoe gap at the bottom of the drum, in the space where the inspection gap is. I had it set to 30 thousandths. I did not apply the service brakes and check it again. I'll do that next time.
This worked on the intermediate axle brake, but not on the rear one.
I really can't imagine that I turned the adjuster all the way out and then confirmed the 30 thousandths gap. I had the gap at 60 thousandths, 15 thousandths and then back to 30 . . . it felt right to me yesterday, but was really wrong today.
dwlindsey
81
California
I did apply the brakes several times at the start of backing out. I agree it sounds weird.
The wheel is off, the front canister is off, the brake shoes are off.
When I get it back together, I'll try to check the drum and make sure it's round. I don't imagine that's the problem, but I'll try to check it.
Ronmar
7,991
Port angeles wa
I guess another possibility is that the spring brakes did not fully release with applied park air? Wonky actuator or wedge? The operation is the sum of all the parts…
GeneralDisorder
5,822
Portland, OR
Those cans are going to apply something like 2,800 lbs of force to retract against the springs that probably push back with 1400 lbs (back of hand calculation based on can diaphragm and 120 psi tank air, and ~60 psi balancing the springs where you start to feel the parking brakes drag) so net of like 1400 lbs pulling on those wedges.... would have to be pretty hung up but maybe.
My wedges and adjusters were really rusted and the parking brake cans just muscled their way past it with ZERO complaints. So much power......
Although there's no linkage to allow the can to actually *pull* the wedge so I guess it could just get hung up and then drum brakes have this nasty property of being self-energizing....... hhhhmmm yeah possible.
dwlindsey
81
California
I thought of that as well, but when I caged the canister, the shoe was TIGHT to the drum and the actuator was extended a lot, not where I believe I put it yesterday. So I don't think it is a park air issue.
At this point, I have no idea what happened. I suppose it's possible that I somehow adjusted it wrong . . . but I checked and re-checked with a feeler gauge . . .
dwlindsey
81
California
I may have figured out what went wrong. It's what I call a "stupid user error". Me being the stupid user
I am learning . . . slowly.
Today I was putting the brake back together with the old adjuster, which seemed to be working fine. I had the drum on and was starting to adjust them to 30 thousandths and I noticed that the drum was not fully seated. I had two lug nuts on but they were not fully torqued down. I guess one side of the drum was 3/16 inch out.
I started over and fully torqued 3 lug nuts.
It's working better now.
My current theory is that two days ago I adjusted the brake with the drum not fully seated, then when I mounted the tire and torqued the lug nuts, the drum seated properly, the adjustment was therefore out and the shoe locked up.
That's a mistake I won't make again. I wonder how many other opportunities for learning I'm going to experience ?
Ronmar
7,991
Port angeles wa
I like me a logical explanation…:)
dwlindsey
81
California
I got the truck out of the garage today. The brakes felt better. I've got all the sand out of two brakes . . . 4 more to go . . . but it already feels better.
In the ongoing effort to remove the spare tire lift, I removed the hydraulic lines from the manifold to the kneeling cylinders. 6 hydraulic lines removed. This gives me better access to one of the bolts on the spare tire lift. Removing that bolt is going to happen on another day.
I power washed the truck . . . again . . . 3rd time. Lots of sand still coming out of hidden places.
I removed the vinyl and foam from the engine hump inside the cab. Lots of sand under it.
I got the cab up using the new hydraulic hand pump. I replaced the cab latch, rather than rebuilding it. When the cab comes down, it doesn't go down all the way because it gets hung up on the cab latch arch. That arch moves fore and aft and looks like it's supposed to move. I don't know if it's moving too much, or if it's supposed to find the right position, but it regularly is just a little too far forward. I've got a weak bungie cord on it now pulling it back, which works, but something's not quite right, I think.
I changed the oil . . . which will require another power wash where oil from the old oil filter got on the frame. Next time . . . change oil THEN de-grease and power wash.
I got just less than 5 gallons of oil out, plus what was in the oil filter. I put 6.5 gallons in and it'll need another quart. Interestingly, the oil pressure is up. I was getting about 35 PSI at idle, now it quickly goes up to 50 PSI at idle. I'm not sure why that improved, but I like it.
Ronmar
7,991
Port angeles wa
Well new oil will do that:)
There are 2 hooks on the cab that engage the stubs on the side of the arch to pull it into alignment at the last second as the cab lowers. You have a little leeway on where the latch can rest fore-aft on the top of the arch, which should help you set the arch fore-aft tilt in relation to those guide pins which help it last minute align.
It should set mostly upright on the shocks inside the air bags, so the shock end bushings inside the airbags have probably disintegrated as I think most of these old ones do. I pulled my old ones apart after I put on my own airbag and shock system, and the shocks felt great, but the bushings were powder and little chunks, besides the bags looking like a cat had been sharpening its claws on them… one still held air though:)
dwlindsey
81
California
The arch is really pretty loose and does not sit up straight. So I'm thinking you're on target that the shock bushings are dead. One more thing to replace . . .
Ronmar
7,991
Port angeles wa
The cab hinge pivots and front bushings also have a say in how the cab sets in relation to the arch and latch. Those rubber bushings are also a consumeable item...
The cab air suspension is quite a bit of unobtanium, it is hit and miss on finding OEM replacements or parts like bags from Power packer. Many have replaced the whole system with one using external cab shocks and off the shelf airbags. I built my own more compact design along this line... Mine rides really nice and the other external shock designs appear to be well received also(I think they all have a little more travel like mine does).
I think General probably has the right idea though. They did away with the cab suspension system entirely on the A1R trucks, but they also added coil springs to the mix on the front suspension... It would be a fairly simple matter to weld up a bolt-in pedestal that re-creates the OEM shock assembly at its mid travel/ride height position... I like designing and building but If mine ever gives me any trouble that is probably where I will go...:)
