Another Ahab
4,735
Alexandria, VA
i haven't used it since the 1970s .. i use good 'ol stinky fuel-oil as a penetrant and as a soak .. And yes i still have an old made-in-usa thumb-pump oil can with long flex spout for those hard-to-get-at precise targets .. I never run out of aerosol pressure this way :p
Good stuff! Yard sales here and there pop those old beauties up now and then. But hard to find for sure now with the world done all gone to plastic like it has.
There's also a shop in Nevada that sells old European military surplus, and they have product like that also now and then (usually old Czech or Swiss surplus).
Deutsche Optik I think is what they're called.
msgjd
3,726
upstate ny
New cable arrived and it's a very good quality cable from the feel of it.
Does anyone here recommend lubing the cable up with cable lube before installing it? Doesn't seem like it has that much lube on it from the factory...
for a long time i have done it to brake cables (civilian & mil) and hydraulic valve cables on heavy equip by stuffing one end into a funnel throat and sealing the joint with a piece of old innertube and hose clamps (rubber hose would work) .. Hang it up and pour bar & chain oil .. It can take minutes to an hour or a day for the "molasses" to start running out the other end, depends on temperature, length, and internal clearance .. It helps to manipulate (or twist if it will twist) the internal cable from time to time.. My neighbor uses gear oil , but i want oil that will literally "stick"
If a cable jacket is steel (no rubber) , I then dip it in a pan of oil before installation.. Yep, it's messy, but i have never had to mess with them again.. Luckily, most hyd valve cables for heavy equip have grease fittings on each end , something i wish was done on parking brake cables
msgjd
3,726
upstate ny
Had a little helper this time!
Little Soldier-B's can stand up and reach places the rest of us can't ! .. Perfect for those catch-22 spots where we can't reach laying down and can't see it squatting or kneeling..
I have one of mine all this week and yep he's gonna get dirty ! :D
(his gramma and mom ain't gonna see him before he hits the tub rofl )
jaws4518
Cold Beer
106
Abilene, Texas
Not this week but last year.:D M931-A1 cab rehab. Actually, going over the entire truck to make ready for hauling. Putting in a back wall mount R-2400-0 RD-2-4369-1 OEM Red Dot Backwall unit. This is the Space X truck posted as my user pic. It is a very nice tractor but it needs a complete going through. I actually drove it home from 200 miles away. Looking back, I am really surprised we made it back without any issues.
US6x4
2,367
Wenatchee, WA
I've had the door weatherstrip pieces laying around for several years and finally got around to putting them on. Driver door required wire wheel, rust converter, primer, and paint before gluing them on. The only glue they had was 3M yellow...wish I had held out for black.
