A/C Diagnostic help
Mogman
10,415
Papalote, TX
So the last issue I am having with my AC, may not be an issue at all. It pertains to the rear evaporator like in the 1165 and 1151.
It will randomly shut off(stop blowing air) and then start back up again 30 seconds, a minute, some short time later. The front evaporator blows as normal during this time. Also, the rear evaporator doesn’t seem to have a high/low setting like the front. It just blows in what I assume would be high, the whole time.
maybe both of those are normal? I wouldn’t know. Or maybe it’s a safety shutoff for some reason.
if anyone with more knowledge of these trucks could chime in, I’m always very thankful.
That evap is likely pulling too many amps and tripping the breaker
thoner7
233
NE TN
I think you’re onto something. Because if I cycle the AC off then immediately back on, it blows again.
I’ll have to figure out what’s causing it, and then order all the parts with my new valve to save on shipping! lol
Retiredwarhorses
4,557
Brentwood, Calif
The rear is an evaporator only, the fan speed is controlled by the hi/low switch same as front, the rear evaporator shuts off when the compressor shuts off, the front evaporator will continue to push air because the blower is still going, this is because the front is also a heater Blower.
You still get front cold air with the compressor off because the air is still forced over the evap coil via the fan, once the proper pressures recover, the compressor will cycle back on and will restore cold air as well as the rear evaporator turning back on….if you are short cycling to often? You are low on R134a refrigeran.
This has nothing to do with over voltage…
thoner7
233
NE TN
That would be frustrating, seeing that I’ve had it back to that shop twice. If that’s the problem I’ll have to take it somewhere else.
is this the best page the manual?
I guess I don’t understand how they measure the weight of the refrigerant? Is it possible to know how many pounds are in there? Or would the gauges just read correct psi going off this chart, and you’re good…?
Retiredwarhorses
4,557
Brentwood, Calif
pressure chart is best, as well as temp gauge inserted into one of the vents while on full, running at 1500rpm…the TM calls for 3lbs 8oz, but that does depends on the pressures banned on air temp.
thoner7
233
NE TN
I did get the 40 degree temp about of both evaporators.
Maybe there’s where I’m confused now. The image above, right side, line item 8 says 5lbs 8oz of refrigerant. So perhaps I’m high, not low?
but as a general automotive question, the guy at the AC shop wouldn’t need to know that amount regardless if he followed the pressure charts?
And my rear evaporator definitely only runs on high .
Retiredwarhorses
4,557
Brentwood, Calif
that 5lbs has to be a “typo”, cuz the service label on the trucks say 3lbs 8oz….but yes, follow the pressure chart.
thoner7
233
NE TN
The rear is an evaporator only, the fan speed is controlled by the hi/low switch same as front…
I could easily be looking at this wrong, but it looks to me like the blower resister only affects the front blower through wire 399, and the rear gets it power from wire 435- unaffected from the resister?
again I don’t have enough experience to know if the rear evaporator blower should go to low speed same as the front, or stay at a high speed as mine does now.
Tiwaz
64
Miami Beach
in my case also the rear blower is always full blast and the HI/LO switch only controls the front blower
thoner7
233
NE TN
My rear evaporator is still cutting out. Takes a little over 20 mins. I do think I heard a “click” from the evaporator just before it cut out, which I’m guessing was the breaker.
I don’t see anything in the TMs about pulling too many amps tho. Any ideas what could be the cause?
