INI Power Systems IG1000-ICMF Info
Piatheem
California
I did a spontaneous purchase of INI Power Systems IG1000-ICMF. I’m a little confused on what fuel it’s supposed to run on. The internet says it can run on anything. The label says JP-8 only. Can I run it on diesel? It did start for me after several tries, but it smokes a lot. Anyone knows what might be the issue?
Coug
4,796
Olympia/WA
Most things that run on JP-8 will run just fine on diesel fuel. Diesel isn't quite as clean as JP-8, but that usually isn't an issue for most engines.
If it were mine I would start putting a load on it and see if it runs any better. Diesel engines like to run hot to properly burn the fuel, so put as much load on it as it runs well with, run it a while and see if it cleans up.
PJL
Way south of Seattle, WA
Ignore the label and run gasoline in it. It's a modified Yamaha i1000 generator. If you run diesel the plug will foul frequently and unburnt fuel will seep past the rings, diluting the oil and causing it to be overfull. That's why it smoke so bad.
If you run diesel or JP8 it will need a lot of maintenance.
My previous post.
Piatheem
California
My previous post.
Too bad, I checked the needle valve in carb and replaced a fuel pump which is apparently a common cause of fuel in oil, but that did not change anything.
Piatheem
California
Yeah, I changed the oil, ran the generator for 20 minutes, and checked the oil level again and it was pouring from the fill hole. I'll try running it on gas, and see if that fixes the issue.
Windwlkr1850
Indiana
Not sure if you are aware or if this will be helpful. The manual states that J8 or similar fuels will produce excess oil that will need to be removed frequently and monitored to prevent problems. I just purchased 2 and the electric starting kit. I want to modify one for propane.
