803A Hits a Wall at 9.3kW
handyjay03
Louisiana
Not to be the bearer of bad news, but cyl. looks pretty bad. Being pitted like that I suspect you have either low compression in that cyl or perhaps no fire at all.
I know you're pressed for time, but if it was mine I would just bite the bullet and go completely through the motor. I've actually fixed several LPW4's in worse condition by using a Lisle micrometer head cylinder hone. I was able to hone the cylinders oversized, starting with 80grit and working up to 400 ( took a long time ) and I got oversized pistons from Mayi Diesel pretty cheap. Or take the block to a machine shop and have it bored. Throw new bearings in it to fix your oil pressure issue and you'll have a brand new machine!
After seeing the more detailed pics I took yesterday, I'm leaning heavily towards getting rid of it. I'm guessing parts and machine shop work is gonna be another $1k, not to mention the time I don't have to do it. Would just end up being another obstacle in my yard I'd have to cut around
handyjay03
Louisiana
Well, looks like I'll never stop being a glutton for punishment. Moved it into the garage instead of listing it for sale. I've never had trouble taking things apart. It's the putting them back together that's going to be tough.
Would y'all advise doing all of this with it in the frame/case, or do I need to pull the engine? Seems like I can get to everything without removing it
Ray70
7,168
West greenwich/RI
It has to come out if you plan on replacing the main bearings. It uses these split ring housings for the mains which require the crank to be pulled out from the rear of the engine to access the main bearings.
I have honed the cylinders out and changed rod bearings with the engine in place, but you have to be super careful to wash the block out good afterwards.
I learned my lesson once, didn't get all the honing junk cleaned out of the far corner of the block and wiped the crank out withing 20 minutes of starting it up!
handyjay03
Louisiana
I'm just going to bring the block to a machine shop to get bored out. Don't want to take the chance of ruining it for good. Never been into anything bigger than a v-twin lawnmower engine, so this will be a learning experience. Are there any one-stop shops for parts, or am I just going to be looking around in eBay for stuff?
Ray70
7,168
West greenwich/RI
I've used a lot of ebay gasket kits and oversized Pistons from Mayi Diesel.
For bearings I found Lister Petter bearings on Ebay.UK You an also try getting them right from Cummins on line, might depend if you end up having to cut the crank or if standard bearings are ok.
handyjay03
Louisiana
Good progress today. Only had an afternoon to do it though. Would be nice if a shop could bore it out without me pulling the injection metering pumps and all of that internal linkage. Am I correct in thinking I'm going to have to pull the stator to get the block out? Discovered my oil container was full, so that put an end to the day.
LuckeyD
363
Vilseck, Germany
Good Day: Just take your time and try your best. If you believe it is beyond your abilities then have the shop deal with it as your wallet can stand. Take notes, use boxes to keep things in, save everything. Usually took 2 days to tear one down in a war zone all the way to the skid. Very messy. After cleaning, it took 4 to 6 days to put it back together as I cleaned everything, tested most things, and usually had Soldiers learning and doing, with training materials on hand for them to use and had a tech manual open so they would see what the book said, then we did. Corrosion with mounting hardware was the biggest issue, followed by hammer and block on bent housing parts that came in, and wiring harness mounting, testing questionable parts, and wire ties. I recommend marking some wires as it may be confusing later on when reconnecting. I did not show them engine tear down, but usually took several blown ones to build one if it had bad components. Usually had to use 4 different main gens to make a good one, but everything had the same parts so the "this is how to test and how it goes together" was the idea. If you get to a point where you require info, please yell. You will have moments to step back and take a deep breath, to move forward. Good luck.
Ray70
7,168
West greenwich/RI
Rather than pull the generator apart inside the enclosure, I'd suggest removing the radiator housing as an assembly, then you can take the engine and generator out as a unit and separate them once they're out.
The radiator housing is only held in by about 6 bolts, it comes out easy at this point.
LuckeyD
363
Vilseck, Germany
Good Day: Member Ray70 is correct. Don't half step this. I found the hardest part was the screws on the slanted metal just in front of the engine fan and that small square of sheet metal around the fuel fill. I rebuilt many and I even removed the center part as well leaving only the engine and main gen on the skid. Then the main gen came off rather easily with few scraped knuckles. I had a couple 2x4s for each side under the rear of the engine to angle the main gen just a bit to get it off easier and I had a small crane doing it too. Remember the torque on ALL those mounting bolts, and lock tight does work. It is a pain but you are better off as getting that heavy engine on a stand or rack to do the work is easier but I found it hard to get done each time. The Tech manual does provide a path, but that's about it. I also reviewed the parts manuals to see what hidden stuff would get in the way my first time. With only the skid it is real easy to start the corrosion prevention and you have full access to the fuel cell. You will be surprised as to what you find now in the skid. Also easier to MIG up any cracks you find. When you use that 24MM socket and impact to remove the bottom pulley, (left hand thread there) and get the governor housing off (note where the longer 10MM bolts go) , take a picture of things as you go so you remember where it goes as you build it back up especially the springs and where they go in the governor, and then MARK the gears where they mesh at TDC. A scribe Awl works well here. You will pull all the pumps again but this time you can put them back in measuring for what shims are required for them with the fuel rack in your hand moving it freely without the springs connected. I'll look for that book on DEPOT rebuild that may help. I'm the SF type nerd who reads then does because i am stupid and it don't come thru osmosis thru my thick head. You can see the first and maybe the second pump tang in place as well and all our bull on how to put them in comes to light. There will be other items where you do the scratchy head trick, but you have folks to ask. I was alone the first time and had mortar and rocket attacks and an entire country full of folks with a Hawaiian disease called " Ima Busted and don knoo what ta dooo" till they read a bit outa a Tech manual. Hard Rock and coffee helped in 130 degree weather, and I only had 3 masters certs from various engine manufacturers at that time and 30 years doing it in GI Joe land.
LuckeyD
363
Vilseck, Germany
I checked thru all 3 of my 4 TB Hard drives for the DMWR or Lister Petter engine book. I can't find them right now. The best thing is the engine Tech Manual which touches on most things which Guy has loaded in the Tech Manual area of the Forum TM 9-2815-253-24 and 24P. I recommend reading then doing. Yields better results and you come out cheaper.
handyjay03
Louisiana
Got a free day today and back at it. After lots of head scratching and reading the manual, I found disassembly easiest by just taking pictures and turning wrenches. The manual hasn't been much help so far, but I'm sure it will going back together.
Going to get the internals pulled out of the engine today, and if I have time, pull the engine/gen combo from the frame
handyjay03
Louisiana
May want to down load the engine manual because it has measurements in it to get it together right.
I've got all of them downloaded when I bought the machine. Have used the engine one for troubleshooting a few times.
Kind of shot myself in the foot today. Injection pumps are stuck like chuck and don't want to budge. I can rotate them, but no matter what, they aren't coming out. Pistons were a PITA to get out too. Kids started getting rowdy, so I had to shut it down for the day
LuckeyD
363
Vilseck, Germany
If the pump tangs are still in the rack, you can use the shut off to get the tang into position to come out. Otherwise, it is remove the bottom pulley and the 10 MM bolts of the governor housing and then remove the rack and the will come out using a coat hanger to get them into the position to pull.
handyjay03
Louisiana
Rotating the fuel shut off didn't do anything when I tried. Couldn't feel it engaging anything on any of the IPs when rotating the shutoff and trying to lift up and down on the pumps.
Looks like the shutoff is no longer moving the black-colored arm. fter some wiggling and jiggling, got them all out.
Took a few hard looks at the crank/cam/governor assembly, and decided to wait on that for tomorrow with a fresh brain. Seems like the perfect opportunity for something to get messed up if I did that wrong
handyjay03
Louisiana
Finally had time to get the engine/gen combo out of the frame this afternoon. That's a heavy beast for sure. It doesn't lile rolling around on an engine hoist.
Did notice about half of the tappets were falling apart, so I've got to figure out how to rebuild them. Some flat metal circles came out of three of them. Not sure what they are for, but it just looks like a leftover piece of steel after using a hole saw on some metal. Haven't been able to find parts online, so might just buy new ones. Not sure if this might have led to a loss of compression
Ray70
7,168
West greenwich/RI
You might want to just get replacements, incase anything internally is missing or damaged.
There is a spring and the pushrod cup but I think there is also a "valve" mechanism that controls the bleed down of the oil, perhaps that is what the discs are from?? If you need lifters send me a PM, I have them.
handyjay03
Louisiana
Lifters appear to be in good shape. Rollers are rolling, and I don't remember seeing any abnormal wear on the cam. Will do a better inspection of parts before I pull the gen head today. Had people over all day yesterday, so I was trying to get what I could get out of the block and the engine and generator out of the frame before football last night
handyjay03
Louisiana
Been a while, but finally got a chance to mess with it again. Stuck all day thinking the end bell cover was getting stuck on by the generator end bearing. After lunch, a beer, and some inspection, figured out it is rusted to the exciter ring on all four points. Tried tapping it with a 20oz hammer and 3/4" extension to possibly knock it loose, but no dice. Would the best plan of attack be to spray some evaporust on it and hope they break apart? Trying not to damage the exciter ring at all, but the shop wants this as bare engine to do the work, so the gen head has to come off
