fuel bleeding procedure m931
allie
15
equinunk pa
if run out of fuel would air get into the system? and Does anybody know the proper procedure to bleed the fuel system on a 1986 m931 tractor w a NHC250 cummins i
CHIEFSONN
yes there is a good chance you got air in the line, add fuel to tank use plunger located on drivers side of motor,there will be a primer valve located towards the rear of the block, above that is a fuel filter ,the fuel filter body there is a 10 mm bleeder bolt ,prime until fuel gets blowen out close valve try to start.
CHIEFSONN
yes there is a good chance you got air in the line, add fuel to tank use plunger located on drivers side of motor,there will be a primer valve located towards the rear of the block, above that is a fuel filter ,the fuel filter body there is a 10 mm bleeder bolt , back it out ,prime until fuel gets blown out close valve try to start.
