Waste Oil in MEP802/3
vrzff
148
33
Mont Vernon, NH
Hey,
Does anyone here have experience burning waste oil in 802/3s? I'm looking to make about 150 gallons disappear, and just wondering if anyone had a negative outcome? I'm mostly worried about clogging the injector nozzles.
I'm aware that burning waste oil isn't exactly ideal, but older engines never seem bothered by it. Most of the farms I work with dump the tractor oil right back into the fuel pod.
Planning to filter and mix with at least 50% HHO. I don't anticipate a proper centrifuge setup anytime soon. Napkin math puts me at about a 1000 gallon break-even point, not counting my time. I need to build my garage before I start making black diesel in that quantity.
I just need the barrel empty to start filling it again.
reset2
102
Myersville MD
I have done WMO in my Ford IDI. Check the Alternate Fuels forum.
For best results without a centerfuge:
5 gallon bucket. Pour in one gallon reg gasoline and 4 gallon WMO. Put a lid on it. wait 4-6 weeks. Pour off 4 gallons of good oil. Scrap the last gallon. The last gallon will have the sludge you don't want to put in your diesel engine.
Sent from my SM-G781U using Tapatalk
2Pbfeet
1,516
Mt. Hamilton, CA
Hey,
Waste vegetable oil or waste engine oil? I wouldn't put the latter in an engine that I cared about. The ash content will come back to bite the engine (combustion chamber and injectors). There are some military documents, and there's this from the EPA;
Lots of ways to get from vegetable oil to reasonable diesel fuel if you are careful.
All the best, 2PbFeet
Ray70
7,178
West greenwich/RI
I've tried it briefly in several things, 803, my backhoe and log splitter, but as 2Pbfeet mentioned, I was worried about ash etc. , so although it worked I decided to save the "black diesel" for use in my steam cleaner. In the steam cleaner burner It is obvious that a smell difference in "gasoline content" makes a big difference in performance, a little too much gasoline and I had flames shooting 2' out of the stack, So perhaps a mistake in formulation could cause issues in a diesel engine.
I'd also suggest visiting the Alternative Fuels Forum.
msgjd
4,121
upstate ny
Although i know of places that dumped their WMO back into the bulk fuel tanks, especially in the days when B-model and R-model mack's were the usual trucks "eating" it, I wouldn't use it. Not only because of ash, but because of increased injector wear from microscopic metal in the WMO .. One particular local trucking company burning it every day/night in the macks openly said it was worth it to them to have to replace injectors versus fuel cost
myself I have been burning a mix of WVO for almost 20 years in heavy equip, trucks, and the MEP's.. However, only when they are active every day or for a long period of time in a day .. Important to flush the system clean with straight diesel before they are shut down to sit for a week or more .. And since cold weather is an additional issue, I use two valve-selectable tanks per item, one with the mix, the other with straight diesel or FO
vrzff
148
33
Mont Vernon, NH
Thank you for that study!
Tinstar
2,621
East of Edmond, Oklahoma
Another way to get rid of some of your waste oil.
The waste oil, mixed with diesel, is a great way to prevent corrosion/rust, when it’s applied to anything outside that will rust from being exposed to the weather.
We do this to prevent expensive farm equipment that sit outside 24/7 from rusting.
Works fantastic
Mix it just thin enough for a sprayer or use a brush.
I’ve even seen some use a bucket and mop.
Just a thought.
msgjd
4,121
upstate ny
I concur about using WMO (and WVO) to spray-undercoat vehicles and treat wood on trailer decks , truck flatbeds, wagon beds etc .. Been doing it 50 years... HOWEVER,,, i learned long ago to avoid WMO coming from diesel engines, especially worn out ones, as back then the wood seemed to punk faster than it should and rust seemed to worsen on treated surfaces that had weekly or daily exposure to water .. It did not makes any sense until i had chemistry class my junior year
per "Search Assist":
"Yes, sulfur can be corrosive to metals, particularly when it forms sulfuric acid in the presence of moisture and oxygen, leading to accelerated deterioration of metal surfaces. This corrosion can significantly weaken metal structures over time"
ibid; "Sulfur itself is not typically corrosive to wood; however, sulfur compounds, such as sulfur dioxide, can contribute to the deterioration of wood when they lead to acidic conditions".
(Such as exposure to water) ..
Sulphur dioxide is created during combustion and can get into the crankcase oil via blowby
Today's ULSD is likely not going to put much sulphur into the oil, and OE itself has/had a small degree of sulphur in it, but i still avoid using WMO from diesels.. I have not noticed any issues with WMO from gas engines , however just about any kind of oil has certain acids and can create additional corrosive compounds in certain situations
Burning waste oils, be it WMO or WVO, comes with certain risks proportionate to hours of use.. WMO can bring injector and IP damage if not centrifuged and ultra-filtered.. WVO can lead to polymerification when burned exclusively over time
Here's a related trivia tidbit that won't affect anyone on here but is still surprising.. Way back I worked at a plastics plant that injected high amounts of freon into the plastics-making process and the "spent" freon exhausted directly into the plant's internal environment at the end of the machines.. Their forklifts were propane-powered and the oil had to be changed every 3 weeks to a month in winter due to doors/windows being closed.. The operators and mechanics knew it was time when their exhaust fumes reeked heavily of burnt sulphuric acid and the oil was yellow sludge. The exhaust fumes would burn your nose when a forklift passed you.. These forklifts also needed motor rebuilds every few years
vrzff
148
33
Mont Vernon, NH
I'm a mechanical contractor specializing in refrigeration. Burning refrigerant, even at relatively low concentrations results in the creation of phosgene gas. It's mostly applicable to older chlorofluorocarbon and hydrochlorofluorocarbon (CFC / HCFC) refrigerants, like R11, R12, and R22.
Happens to me all the time, even flowing nitrogen while brazing-- there's always refrigerant left in the system somewhere (usually suspended in the oil) even with "proper" recovery. Much worse when I'm working in a confined space.
That's why the forklift exhaust probably burned your nose and watered your eyes.
williamh
716
SanDiego Ca.
I spent 40+ years choking on that crap. That’s why I never tried using old refrigeration oil ( mineral or poe ) in my Duce. It would just destroy everything. Especially if it had any acid from a burn out. F that job. I’m retired now 🥳 and don’t miss it one bit.
msgjd
4,121
upstate ny
I'm a mechanical contractor specializing in refrigeration. Burning refrigerant, even at relatively low concentrations results in the creation of phosgene gas. Happens to me all the time, even flowing nitrogen while brazing-- there's always refrigerant left in the system somewhere (usually suspended in the oil) even with "proper" recovery. Much worse when I'm working in a confined space.
good to know !! ,, whatever it was it sure smelled like sulphuric acid (and that's what we all thought at the plant) and it sure made a mess of engine oil and the internals
