Turbo specs for the deuce.
mahdey
Ft. Knox KY
Does anyone know what the specs are for the turbo on these trucks? ie. 58/65/12? Also does anyone know the footprint of the turbo whether it is a t4 or t3? I'm doing a twin turbo set up on my cummins and the hx35 will be tossed to the side and got to thinking if i should throw it on the duece if it is bigger. I see a lot of guys are having egt issues (1200 degrees seems low to me but it must be the engine) and i figured a larger turbo will bring them down under control. Fabbing an adapter to the manifold will be easy a well as everything else, jut need to know if the deuce turbo is smaller or not.
OPCOM
29
Dallas, Texas
somewhere around the BBS is a turbo map for the 5 ton. Not the same but worthwhile. I believe it is a bolt on (and someone has done it?)
