One more IP question
panzerjunky
san diego ca
Got the Engine to bump got my O-Rings in fine question is.
Is the control rod inside the IP That is controled by the engine shut down cable supposed to move back and forth freely or is it tight with no play?
Thanks Jerry
gimpyrobb
dumpsterlandingfromorbit!
27,787
779
Cincy Ohio
Freely! When you push it back(like in "fuel off")position, it should spring back to the forward(fuel on) position when you let go.
panzerjunky
san diego ca
Hey Gimpy
I am not talking the part that is attached to the cover that you remove to see the timming marks I am talking about the control arm in the IP the part with the e-clip on it mine is tight what would cause that any ideas?
Thanks Jerry
panzerjunky
san diego ca
Thanks Guys
I didnt torque the screws just snugged them down will lossen until unit moves freely then re wire.
Thanks Jerry
PS Cranetruck where do you get such clear images to work from I am jealous.
