Blown multifuel motors
GoHot229
With the recent number of multifuels that have cut loose lately, I thought those who experianced a grenaded engine could post when and the extent and the theory of what might have been the culprit. So if you could list the type/manufacturer of motor.
What aparently blew.
The date (aprox).
How you were driving ie. what RPM's and Speed.
And any comment you'd like as to why you think it went south.
There seems to be a common denominator here that is comeing to light....and that is the number six rod blowing. The last to recieve oil may have everything to do with it.... We all know the two best solutions to oiling is to get the Spin-on oil filters, currently the easiest to come by, JTonka's. They are anti-drain back thus leading to a quicker lube time, and ofcourse if we incorperate a pre-luber, we have effectivly addressed all of the shortcomings of the oiling on the multifuel.
The other thing that seems to be apparent in blow's is maxing RPM's for extended lengths of time, or esentially the same thing, trying to run at 60+ mph. I'm gathering that some of us, some of the time, DO run this way. And also that there is probably a larger number of us that do not.
jwaller
19
Columbia, SC
there is an entire topic that covers this with info from the military and all the possible reasons why. you'd be very surprised at the information contained in that topic.
stumps
12
Maryland
Yes, but much of the surprising information had to do with the military users of the engine. We, presumably, are more gentle on our engines, and don't do things like stuff gasoline soaked rags into the air bell, and then run at full throttle.
-Chuck
stumps
12
Maryland
The date (aprox).
A couple of additional questions I would like answered:
1) Was the engine remanufactured? If so, who did it?
2) Which cylinder threw the rod? (#1 front, #6 against firewall)
3) Was the crankshaft journal burned and scored, or still shiny?
4) Was the rod cap still attached, or were the bolts sheared free?
-Chuck
dmetalmiki
2,036
London England
NO oil pressure on start and non for too long after!? is WHY Ive fitted pre-lube pumps on all my trucks! well at least I feel that more reasured/happy with (at least) 15lbs pressure BEFORE I hit the go button.
stumps
12
Maryland
That helps prevent dry bearing wear on start up, but I don't think it has anything to do with the rod failures that are vexing us. None of them look like seized bearings; all that I have seen (so far) look like over speed failures.
-Chuck
stumps
12
Maryland
Going to get a Christmas tree and running in the NAM are related how?
The only similarity it requires, I believe, is long periods of high RPM operation of the engine.
A deuce with standard tires, tooling down the road at 55MPH, is rather a kin to running a passenger car at the redline continuously. It works for a while, but in the end it will shorten the engine life.
-Chuck
stumps
12
Maryland
Chuck you aren't speaking from memories are you ????????:twisted::twisted::twisted::twisted::twisted::twisted:
I'm way to conservative to ever be a racer, but I have a number of friends that get their kicks pushing the iron past its safe limits. It works for a while, but in the end it results in a 2 or 300 hour engine life... sometimes much less.
I have never seen anything detailing the design parameters for military engines, but I have no trouble at all imagining the designers allowing the operator to push the hardware well beyond the safe limits... All I have to do is recall the WEP position on the old piston engined aircraft throttles. Use it once, and a rebuild is in order.
-Chuck
GoHot229
I more or less was interested in a count of blown motors over this year, it seems two motors just blew in as many days here on the forum posts......and a couple last month. But if modified motors blew at significantly larger or smaller number some correlation might be arrived at, who knows.....
jdmcgowen
Klamath Falls, Oregon
Does high compression play a factor here? Seems to me the multi's have really high compression, and that would incur more stress on the rods. At high speeds it may just be too much. I think I'll slow mine down.
SCSG-G4
PSVB 3003
5,399
3,490
Lexington, South Carolina
#6 is the last to get oil pressure on startup, so it's logical that it is where the most problems would come from.
When my engine had it's little 'adventure', it was running about 2400 rpm's. So I've been running the one I took to the GA rally between 2200-2300, usually on the low side. That one only drops down to 2100 pulling the MKT on all the local area interstate hills. I don't mine going 48-50 MPH if I don't have to replace engines - just takes a bit more planning to arrive on time.
stumps
12
Maryland
Did yours throw #6 too?
A few more #6's, and we might be justified in declaring a trend. Perhaps this is why they upped the flow on the oil pump in the LDS engines?
-Chuck
stumps
12
Maryland
By "modified" do you mean rebuilt? I was curious to see whether the factory built engines fared better than the Toole rebuilds.
-Chuck
m16ty
227
Dickson,TN
If you look at other diesel engines of similar size and vintage of the multifuel you will find that most of them list max RPM at around 2100. IMO running at 2400+ is just too much.
One more thing to consider is that there is no telling how hard your truck has been run while in the military. More than likely all of our trucks have been ran at redline and beyond while they were in service.
Another thing that would be interesting to know is what unit the trucks in question came from. I have found out that my truck came from a maintenance unit of the TN/NG. The truck never left the NG base and was only used to haul maintenance items on base. I tend to think it had a much easier life than most other trucks.
