Westex
- 6
- 18
- El Paso, TX
Anybody ever found a welded rocker arm on their Deuce; Tooele rebuild and discovered while dealing with a leaking injector pump.
Ok, If that's what we are talking about it makes sense. I was picturing a rocker broken in half and welded back together.well the center of them have a weld/braze point.
This helps; I don't yet know where the weld is; the truck is at a fuel injection pump repair house in San Antonio. They are familiar with pumps. Probably not multifuel nomenclature. I'm going to hold my breath and hope it's the center of the rocker which if I understand this right is the weld point through the axis of the rocker on the rocker shaft.Ok, If that's what we are talking about it makes sense. I was picturing a rocker broken in half and welded back together.
