Where to buy door seals /windshield seals
CPAPPY
Xenia , Ohio
I am wanting to find a good source for door seals and window seals , I have use LMC but the door seal seems to be to firm that you need to slam the door shut . Looking for some thing like factory quality. I have heard that the LMC windshield seals are junk .
lindyp38
ulster county ny
if u have to slam ur door shut....id like at the door striker pin.......u are probably missing the plastic bushing that slides over the door striker pin shaft......
do a search here.....the fix is really simple......
CPAPPY
Xenia , Ohio
No that's not the problem. they seem to be to firm . Thee door shut good before I put the seal on , the gap around the door was very close to being the same , I would sayI am compressing it only about .125/ .187 max.
ranchhopper
139
south elgin illinois
If your useing new door gaskets it will take a while to compress shutting the door requires keeping your hand on the handle pushing it shut eliminating the bounce that keeps it from latching.
Sharecropper
1,220
Paris KY
The LMC door seals are fine, but the LMC windshield seal is about 3 inches too long. I threw mine in the dumpster and found a NOS seal at an obsolete parts dealer. Get the GM parts number and Google it - you will be surprised what pops up.
ranchhopper
139
Yes that is a problem buying from LMC I always search out OEM parts twice the price but Im not going to support china and not to mention the aggravation trying to use parts that dont fit.
Sharecropper
1,220
Paris KY
I recommend using NOS GM parts if possible. GMPartsGiant dot com is a good place. Just enter the GM part number in the search box and... Presto!
CPAPPY
Xenia , Ohio
Are you saying you had the same problem with the door seal . I have never up in a windshield seal... yet.
