David Sims
- 0
- 0
- Middle Georgia
I had my 90 hour MEP002 powering the shop this weekend and noticed it did not sound right when the air compressor turned on.
I took a 1650 watt space heater to the generator while it was running at 60HZ and about 25 % rated current; plugged it in and watched the HZ drop from 60 to about 56HZ. Waited a few seconds and it continued to run at about 56 HZ.
I connected the shop to the 2750 hr MEP 002. Repeated the same test with the space heater and the unit stayed at 60HZ.
Back to the 90 hour machine. The Manual on page 4-23 shows the Governor Linkage. Over a couple of hours time I moved the linkage in and out and tested in between with the space heater and did not see a significant change.
Then on page 1-4 it shows the Governor adjustment screw. I then turned the screw on the Blower Housing with the unit running at 60HZ. Screw it in a couple of turns and test with the space heater. So on and so forth until I had run it in and out all the way.
If anyone has the procedure for setting the Governor I would appreciate it.
