12volt conversion finished
choll
Las Vegas,NV
Well after months of trying to figure out why the front battery didnt charge, I did every check according to the TM's, I coverted the blazer to 12v. It was pretty straight forward. Only had to cut one wire. the rest of the wires were just taped up and then wire tied in an out of the way place. Its working great, I now have 14.75v at both batteries when the truck is running. No more hooking it up to a battery charger at night and I can use the truck at night on my long work drives.
It only cost me a total of $60. That was to rebuild a 12v starter that I had in the garage.
Warthog
241
OKC, OK
What runs off of 24 volt originally? The alternator and starter, but what else exactly?
The alternators are 12 volt. Only the stock starter is 24v. If you search you will find hundreds of post about this.
The glow plugs are 12v but use 24v to operate.
choll
Las Vegas,NV
I did use the rosscommon. It was to simple. I didnt expect it to start because I never get things right on the first try. The only thing that was diffrent from the instructions was the glow plug relay wire was not hooked uo to the big resisters on the fire wall it was hooked up to the 12v terminal on the fire wall.
midcounty
26
Preston, MD
A M1009 that I just bought was converted to 12v, but the guy I bought it from bought an entire wiring harness from Painless and rewired the entire truck. I bet he would have liked to have known it didn't have to be that involved aua
True Knight
182
San Pedro, CA
Heck, better for you though!
This is a mod I will definitely do in the future.
