I would have to go with the nut between the front seat and steering wheel !!!
thats the nut 1 have the hardest t1me w1thAny one you can't get to with an air ratchet/impact wrench and can only get 1/8 of a turn on with a box end wrench that you have had to cut down to get into the tight space that was designed by an idiot after consulting with a moron.Which is the Hardest Bolt or Nut to remove from the Deuce
I sold the pintle hook off my parts truck and i couldn't get it off, so i cut the rear cross member off.i think the big nut on the pintle was the most pita of any i can remember taking off..i think it was a 2.5 inch socket and you have to hold the pintle from spinning while trying to get the big arse nut to break loose .i had to use a pipe and a floor jack to get mine loose
If you use a 1/4" ratchet with a 10" extension and go in from the other side the the cross member, it is a snap.Lower bolt nearest the frame for master cylinder, it's a booger.
lower bolt nearest the frame for master cylinder, it's a booger.
Been awhile but thought that there are three studs on the front gear cover and if you put a jam nut on the correct three the IP and the spacer plate come off as one. Then you don't have to fool around with the hard to get to bolts that hold the IP to the spacer.injection pump to houseing bolts i made a wrench just for that job made it easier
