Desperado08
- 0
- 0
- Vallecitos/NM
I need to know what type of grease you can use in your knuckle boot for an m35a2 2.5 ton. Thanks and is there an alternate that I can buy from an auto parts store or is it special order only.
The boot does not need grease.
Thank youThe boot does not need grease.
Sometimes (ok, most of the time) I do notice it right away but will let it go for a little while because I don't feel like tearing into it.I figure if nothing else it will provide at least a little protection from dirt and water if one of the boots tear and I don't notice it right away.![]()
Diesel bob. if nothing else it will provide at least a little protection from dirt and water i 2cents[/QUOTE said:I believe that by not putting any in there if you go swimming and you don't want to open it up and check for water right away you can do this. You just take out one of the 4 bottom bolts that that hold the end caps on the bottom and most of the water will drain out.
I have never cleaned out and repainted one to be pretty but I spray WD 40 all over and I'm done.
I put a good amount of grease in the spindel on reinstalling and in wipe off exess when the axle pops out.
