002A Ran for 1/2 hour (exersise) today then won't start???
joesco
Hampstead, NH
You and others were the professor(s) and I was student, but I sure have leaned a lot and the intimidation factor is just about gone!
Great job Joe, By the time you get all of the little quirks worked out of the set you'll know those generators like the back of your hand!!!!
wciguy
Lubbock, Texas
Give the starter a whack with a hammer. When the brushes get too worn to make good contact on the armature commutator, the pull-in winding of the starter solenoid will not get its ground and the solenoid will pull maybe 10 amps as the hold-in winding still gets its ground to the solenoid case. If the starter works after the hammer encouragement, the brushes are worn out, or the armature has an open winding(usually where the bars are soldered to the commutator risers.
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
That's excellent advice, but he already got the problem fixed :beer:
storeman
52
Mathews County, VA
This is a year-old post by Joesco. But, I'm curious as to what you are describing as the starter lock out switch, and how it is adjusted. Please provide more info.
Jerry :beer:
178
Jackson NJ
Mep starting issue
Hello and hope thinga are good by you. Reading your post and I had a similar problem last year with my 002. Turned out to be the starter lockout switch was out of adjustment
